![]() | Home > In Car Electronics > GLOHH lighting system for Defenders |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3797 ![]() ![]() |
https://glohh.com/pages/gl2x
Not sure these are actually any brighter? than the LED's I already have but something a little different. I've yet to change the headlights (just have higher power bulbs and wipac clear lenses) https://glohh.com/pages/gl-2-front Thoughts... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5806 ![]() ![]() |
I was told. If you have nothing nice to say, then say nothing.
I have nothing to say about these lights. ![]() ![]() ![]() |
^ My wife tell me that A LOT these days...
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2283 ![]() ![]() ![]() |
Mo The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 830 ![]() ![]() ![]() |
Fitting them is fun, especially the front ones.
I like them as I get dual brake lights. Also dual fog/reverse lights Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
mmddbb Member Since: 15 Sep 2021 Location: UK Posts: 16 ![]() ![]() |
For anyone that has fitted these, any tips for getting the bolts at the back done up on a 110? Seems like an impossible task - can’t even get my hands up there and past the mud cover at the moment…
You need to remove the mud covers, remove the inside covers also Searching for my first Defender...and started just as Covid hit, so talk about timing.
Any tips on how to get the rear inside covers out? These are the things I am struggling with most at the moment as they are preventing access to the studs on the lights.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1144 ![]() ![]() ![]() |
Just based on the advertisement style, I don't see much technical improvement but more a life-style-orientated product. Its not as much a product more of a fleeting Instagram moment. I am sure they will be alright, but also a lot of money with styling not as timeless as the standard lights (LED or conventional), which also happened to be quite cheap. Also I wonder how much side view you get from say the indicators. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17603 ![]() ![]() ![]() |
They remind me of the plug hole in the kitchen sink.
Not a good look, in my opinion, however I realise that others may love the look. To each his - or her - own. |
Whatever your thoughts on the look, can confirm they are hard to fit… I don’t see why they couldn’t have engineered a better way of attaching them to the body work from the face side given access to the back of a Defender is pretty tricky. Taking a pause at the moment with them dangling off the back as I can’t access the fitting studs, which is pretty annoying as they also weren’t the easiest thing to connect up.
I do see some benefits in more and brighter indicators and reverse lights, but agree it’s a pretty niche and expensive product at the moment. |
Without looking there is 2-3 push/screw plastic rivits. You need to pull the upper window covers first if fitted, they just pull away. Then lift the inner panels up. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
