Home > Maintenance & Modifications > Ashcroft LT230 1.100 Gear Set
Page 3 of 4 <1234>
jst
^^ i concur with this, i was surprised to see a coolant and egt drop. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1056715 8th Jan 2025 8:46pm
andy63
Most probably my mistake in that naks didn't say the coolant temp had dropped..that's just me making another assumption😫, and relating the coolant to the mention of a drop in exhaust gas temp...
Still find any drop in running temp odd when adjusting ratios in that way mind, but 20 deg on exhaust temp which can fluctuate wildly is possibly not meaningful..
Post #1056719 8th Jan 2025 9:16pm
ashtrans
Site Sponsor
Naks wrote:
Finally managed to go for a highway drive after we got back from the holidays, and it is such a pleasure to drive now!
At 120kmh (speedo) it's sitting a tick over 2000rpm, running much easier than before.
EGT is also down about 20C, and oil pressure is down by about 0.2 bar.
All in all, a really nice mod, pity the transfer case didn't die sooner, this would have made a major difference to my fuel consumption over 10 years Rolling with laughter
Great feedback,
glad you are pleased with the gear set Thumbs Up Dave
Post #1056842 9th Jan 2025 8:29pm
MK
Did you get to fit the larger sump? Puma 110" SW
Post #1056884 10th Jan 2025 11:54am
Naks
^ yes, indeed. I haven't looked at the transfer case oil temperatures though.
After a few hundred kms, I have noticed that the pre-fitment drivetrain issues have come back: the clunking when coming to a stop, the vibrations, and the high-pitched whine.
The car now also 'grabs' when I come off the accelerator, and where before I could idle in 2nd gear, it now jerks and stalls.
So not too sure if the latter is as a result of the different gear set, or if there was a fitment error, or what... --
Post #1058773 28th Jan 2025 6:23am
jst
Props ref drive train knocks etc? What are they like?
You mean coast at idle revs with in 2nd? Going to that gearstick it won't pull it at those revs and will stall, function of the gearing I would have thought. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058774 28th Jan 2025 6:53am
Naks
Some clunking when coming to a stop, drivetrain vibrations at 2000rpm, high-pitched whine when coming off the throttle
Yep, coast at idle in 2nd, although I do get that this is the new gearing.
But the sudden grabbing when I come off the throttle is very off-putting. --
Post #1058803 28th Jan 2025 2:52pm
jst
Handbrake getting warm? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058823 28th Jan 2025 6:46pm
Naks
^ can't say that I've noticed any increase in temps.
A bit difficult at the moment as ambient is +-40C --
Post #1058876 29th Jan 2025 1:47pm
MK
Whine noise probably coming by fitting together new and used gears.
At such high ambient temperature you would be better off using something like 75W-110 gear oil. Not very common oil spec. Puma 110" SW
Post #1058967 30th Jan 2025 11:20am
Naks
no, the whine was there before.
First we thought it was the rear diff, so we pull it out and fitted new bearings, etc.
Then we thought it was the transfer box, so we rebuilt it. --
Post #1058984 30th Jan 2025 1:16pm
Mo Murphy
Rear diff ring and pinion can whine when worn, did you change those ?
50 Shades of Pennine Grey
Post #1059006 30th Jan 2025 5:49pm
Naks
Mo, that's a good question.
It's going in on Feb 10th for the annual service, will ask them. --
Post #1059062 31st Jan 2025 4:33am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Did you try to run the car without one prop shaft and wirh engaged center diff lock? This way I was chasing broken diff, when car was jus a bit noisy from somethink. I was trying first to find what to look into, than just startin dismantling parts. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1059236 2nd Feb 2025 8:48am
Naks
Ok, so the handbrake cable was loose, but the one pin was bent, so the handbrake was catching.
It's all getting sorted out, and they are also re-looking at the rear diff whine & backlash. --
Post #1060241 11th Feb 2025 4:41pm
Page 3 of 4 <1234>
