![]() | Home > Technical > Almost broke down |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
When did you last have a fuel filter?
julian Member Since: 17 Feb 2017 Location: Devon Posts: 148 ![]() ![]() ![]() |
Clutching at straws, I'd consider a turbo hose delaminating.
This would fit with it running ok on boost / partial boost but failing when approaching a roundabout when it would, effectively, be naturally aspirated. Black smoke sounds like too much fuel / too little air so I'd be surprised if it was a fuel restriction, but you never know. Of course, a stuffed air filter or the hose to the turbo would also do it, but that wouldn't happen when you were decelerating. You said that the smoke didn't smell much. If you change your mind or it starts to smell like burning tyres, pull the intercooler and see how much oil you can pour out of it. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
Any possibility of any obstruction sucked in the air intake, inc to the air filter?
A workshop glove, leaves, blue paper roll, or similar things can easily go in. Long shot, but is possible. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
Intercooler hoses, collapsing or just being loose 1995 Defender 110 CSW
1971 SIIA Lightweight |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 919 ![]() ![]() ![]() |
As above. Sounds like a possible hose/intercooler has split. 2008 2.4 110 Utility Station Wagon XS.
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 571 ![]() ![]() ![]() |
If there was an oiled air filtre, I'd check that one. Turbo hose split normally causes loss of engine power but not limited to walking speed. |
anotherrick Member Since: 02 Feb 2024 Location: Lancashire Posts: 33 ![]() ![]() ![]() |
First of all thanks to the replies above. I took a look and all pipes appear "ok" for thier age.
However the issue has occurred five times over the last several days and it's definitely fuel related. I know this from the very strong smell of fuel i can now smell when it happens. Same symptoms as my first post but it only seems to happen when the car has been driven at higher speeds i.e. duel carriageway/motorway speeds and only happens when coming off the throttle to slow down. Then will just about idle or ill turn it off for a couple of mins then it'll start fine and I can carry on. So far anything below 50mph and I can drive round all day long. |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 839 ![]() ![]() ![]() |
Well, 50 mph is quite a bit more than walking speed ![]() Could be thé turbo then. There's a guy experiencing the same issue on his Puma. He's doing a lot of investigation / testing in order to sort this out. Just look in the tdci section. |
