![]() | Home > In Car Electronics > The definitive Defender ICE thread |
Baytown Member Since: 30 Jan 2016 Location: Cairns Australia Posts: 87 ![]() ![]() ![]() |
Thanks for the in-depth reply Custom.
Re the Purple and white, nope, didn't do anything and isn’t labeled Camera or trigger, how ever the incorrectly coloured green and white trace did work. As per the attached photos, the loom doesn’t match the instruction diagrams. Re the fuse, I always fuse immediately off any power supply. I’ll see if I can find the suitable connector block that the Rear Camera In RCA plug is connected to and only run that line to remove the extraneous audio cables, if not I’ll see if I can de pin the block vs cutting the lines. I live rurally so a definitive supply place in Cairns Australia is 100kms away. Thanks again for the great reply. Ken👍 ![]() Click image to enlarge ![]() Click image to enlarge 2012 110 LS3 6.2 V8 - 6 Speed Auto |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
I see what you mean, it might be the I.D. Heatshrink / tag has been put on the wrong wire colour when made, and then put in the wrong pin housing on the block.
Then they matched the tag to the pin location but not the wire colour. ![]() You can get keys to unpin, that is what I’d do too, what a pain. If you can heat the shrink you can likely slide it off, if it’s adhesive a bit more tricky, worse case very carefully slit it along its length, put it where it should be and a little clear over the top to keep it in place. Or a PVC adhesive electrical tape, fashioned into a flag, and you can write on it with a sharpie. ![]() ⛽️🛢️⚙️🧰💪 |
Good on you mate, I’ve a Dymo that I can label with and routinely mark my cables with. I should invest in a heat shrink labeller, that would be great. I’ve a set of de pinning keys - pins here so will see if they're suitable, although its a pretty small pin access.
I’ll post what my outcome is.👍 2012 110 LS3 6.2 V8 - 6 Speed Auto |
As discussed, I de pinned the speaker connector so that only the ‘Camera In’ line is connected vs the spaghetti mess involved with connecting the cable with the un needed RCA plugs and three other cables.
Removing the individual cables was easier than expected, just requiring lifting the tiny plastic tabs and pulling the cables out. Best part is it should be easy to reassemble the loom if needed in the future should I fit an external amp. That will make the cable clutter behind the AV unit a little easier to manage.👍 ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2012 110 LS3 6.2 V8 - 6 Speed Auto |
Good work.
![]() Yes, reducing bulk of wiring behind there is a good idea, also any longer wires, it’s a good idea to secure and protect them within reason so they don’t get stuck in or around the heater controls as they can get jammed up, not only stop them being operated but damaging the wires too. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
