Home > Td5 > Recommendations for heated seats |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8150 |
personally i would fit std XS seats, they are heated and comfy and fit.
i had merc seats in a 90 once, butons really close to door so you had to open door to adjust seat, and far too high but they were comfy. i drove it home with them in and then removed them. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
13th Jan 2025 12:50pm |
PoormansXS Member Since: 21 Oct 2023 Location: Lincolnshire Posts: 55 |
Have you seen the premium seat upgrade kit from exmoor trim? That’s my plan when I get round to it (must use puma style seats) plenty of options for material/colour
13th Jan 2025 8:08pm |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 139 |
Yeah, I'm 50/50 at this stage, although having a quick look online, there don't seem to be too many options on the LR XS seats currently. Most are expensive and a bit tatty. I'm thinking to fit an Anderson connector or remote battery posts to limit the potential of needing the passenger seat base out. On the driver side, I suppose needing access to the ECU would mean that taking the seat out (x4 relatively accessible nuts / bolts) wouldn't be too much of an issue. I have a question on aftermarket seat heating, but I'll post that separately. Cheers. Defender 90 TD5 2004 |
14th Jan 2025 9:33am |
Thanks for the tip. However, as I don't currently have puma seats, this probably doesn't make financial sense for my particular situation, but I see that it's a nice upgrade for someone that has. Cheers. Defender 90 TD5 2004 |
14th Jan 2025 9:35am |
maranellohouse Member Since: 03 May 2014 Location: Northern Ireland Posts: 18 |
I fitted Saab 9-5 estate seats to my 110 a few years ago both front and rear, Had to do a little metal engineering on the rear seat but they are all heated and work fine.
Click image to enlarge Click image to enlarge 05 Alive tuned TD5 110 Defender 73 Fiat 500 F 53 Massey Ferguson TVO 92 Kawasaki ZZR 600 97 Ferrari 456GT www.maranellohouse.com |
24th Jan 2025 1:55pm |
