![]() | Home > Td5 > Recommendations for heated seats |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8201 ![]() ![]() ![]() |
personally i would fit std XS seats, they are heated and comfy and fit.
i had merc seats in a 90 once, butons really close to door so you had to open door to adjust seat, and far too high but they were comfy. i drove it home with them in and then removed them. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
PoormansXS Member Since: 21 Oct 2023 Location: Lincolnshire Posts: 56 ![]() ![]() ![]() |
Have you seen the premium seat upgrade kit from exmoor trim? That’s my plan when I get round to it (must use puma style seats) plenty of options for material/colour
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 140 ![]() ![]() |
Yeah, I'm 50/50 at this stage, although having a quick look online, there don't seem to be too many options on the LR XS seats currently. Most are expensive and a bit tatty. I'm thinking to fit an Anderson connector or remote battery posts to limit the potential of needing the passenger seat base out. On the driver side, I suppose needing access to the ECU would mean that taking the seat out (x4 relatively accessible nuts / bolts) wouldn't be too much of an issue. I have a question on aftermarket seat heating, but I'll post that separately. Cheers. Defender 90 TD5 2004 |
Thanks for the tip. However, as I don't currently have puma seats, this probably doesn't make financial sense for my particular situation, but I see that it's a nice upgrade for someone that has. Cheers. Defender 90 TD5 2004 |
maranellohouse Member Since: 03 May 2014 Location: Northern Ireland Posts: 21 ![]() ![]() ![]() |
I fitted Saab 9-5 estate seats to my 110 a few years ago both front and rear, Had to do a little metal engineering on the rear seat but they are all heated and work fine.
![]() Click image to enlarge ![]() Click image to enlarge 05 Alive tuned TD5 110 Defender 73 Fiat 500 F 53 Massey Ferguson TVO 92 Kawasaki ZZR 600 97 Ferrari 456GT www.maranellohouse.com |
andycowman Member Since: 22 Jan 2025 Location: devon Posts: 12 ![]() ![]() ![]() |
@maranellohouse that looks great! I have RX8 seats up front in mine which work well being a bit tall. How are the Saab seats for head room?
In the rear can you remember what you had to do? Do they tip forwards? Many thanks Andy [/quote] |
Hello - I have a set on XS seats going spare! In Devon if there is any interest |
