Home > My Defender > Fuji 110 LS3 build
Page 62 of 64 <123 ... 61 626364>
mcma1
Decided to attempt a custom Wolfbox install to kill many birds with one stone. I have ordered a 10" system but I want to try and keep it as tidy as possible and not strapped over the current mirror. First step was to scan the original mirror leg and design / print a cover piece so that I can run the cables up the back hidden away. When I get the new mirror tomorrow I plan to print a simple mount but with the original socket bonded on so that the mirror can be adjusted. In theory when installed I will have the visors cut for clearance and re trimmed in Alston.
 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1058170 21st Jan 2025 9:31pm
mcma1
Made some progress. Have the new mirror leg cover ready for paint and the socket piece removed from the older mirror. Just waiting for the kit to be delivered and the last part will be the bracket on the back of the Wolfbox to print. I think it will look spot on when I paint it all in
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058260 22nd Jan 2025 5:54pm
jst
Good idea, I like it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058291 22nd Jan 2025 10:43pm
mcma1
Thanks, Wolfbox arrived late afternoon so got the mounting plate drawn up and printed, you can see the socket from the old mirror bonded into the print. Just didn't have long enough M2 screws but should get it fitted tomorrow and hopefully wired up at the weekend. Thumbs Up
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058292 22nd Jan 2025 11:07pm
Zed
Seriously brilliant work as usual! If you ever decided to print off more I would gladly buy one from you. WARNING.
Post #1058297 23rd Jan 2025 1:49am
jst
Likewise. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058302 23rd Jan 2025 7:32am
mcma1
Don't think that would be a problem Thumbs Up . Just need the hard wire kit and upgrade WDR camera to arrive and I can get it all put together. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058306 23rd Jan 2025 8:48am
Les Brock
What they said ...be interested if you decide to print more
Post #1058308 23rd Jan 2025 8:55am
Black Puma
United Kingdom 2011 Defender 90 Puma 2.4 SW Sumatra Black
Amazing! I tried a few modeling software's for days and days over Christmas. It is not at all simple (it hurt my brain so much), as well as the 3d scanning. Outstanding work Thumbs Up
Post #1058313 23rd Jan 2025 10:27am
jst
Which camera did you go for? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1058316 23rd Jan 2025 11:28am
mcma1
I just went for a G930 / WDR camera bundle that was on offer via Amazon. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058328 23rd Jan 2025 2:50pm
I think you’d have a hit there with that. Good work. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1058331 23rd Jan 2025 3:04pm
pistonfields
Switzerland
looks brilliant! where will you be mounting the camera? Was thinking about getting the G930 myself but wasn't sure if it would be worth it; not sure how it is at night... I'm easily irritated by all the lamps and gauges and stuff. I'd like to have full submarine combat mode: only red lights, and as few as possible.
Post #1058356 23rd Jan 2025 8:49pm
mcma1
The rear camera? I will likely place it on the roof. I am really doing this to gain the reverse camera function without having a double din install, dash cam recording is just a bonus!
Got some M2 screws and could finally fit it up. Visors can got to vertical only as expected so I am going to buy some used ones from ebay tonight and cut/retrim them.
The only negative beyond my control is the cable connections to the Wolfbox as they slot into the top so I am going to print a small cap/cover to hide them.
Into the headlining I have beefed up 2 of the 3 bolts holding the mirror bracket so that I can lose the 3rd bolt and dremel out a channel for the cables to feed up thru the bracket. I think this is about the best I can do given what i started with.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058370 23rd Jan 2025 9:30pm
L110CDL
Great work there Andy, loving it Bow down Clayton.
Keeper.
Post #1058378 23rd Jan 2025 10:02pm
