Home > Maintenance & Modifications > sound proofing TDCI
Page 3 of 3 <123
jst
I have Wright kits in the working trucks. It's easy to clean looks great and helps deaden noise alot.
My 110 has sound proofing stick on panels and then foam and then carpet and it's comparable to wright kit in my 130. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057608 16th Jan 2025 9:34pm
mptzs90
 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Did you stick down the foam or just lay it under the carpet? I'm trying to work out how not to create a total mess by cutting lots of different sections around seatbox covers and gearbox plate since it sounds like you really want it to cover all areas if poss.
Post #1057610 16th Jan 2025 9:48pm
jst
Laid it Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057616 16th Jan 2025 10:19pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
You can get pre cut foam/vinyl mats from noise killer to go over the butyl later and then fit the carpet on top. I found the seatbox didn't have enough clearance to the door to fit the panels there, but I know others have.
I ended up replacing the noise killer and carpet with the wright off road matting. It has guidelines under the seat area so you can easily cut flaps to get to the battery and ECU areas. It is very heavy so having a spare pair of hands when you fit it will make things easier.
I'd say the soundproofing is similar between the two options.. But I still need to swap out the solid mass flywheel and clutch as it is so noisy and I also need to improve soundproofing in the tunnel around the gearbox turret. These two issues are generating a lot of excess noise so it's hard to properly determine how effective the matting is.
TBH I've been a bit distracted on another vehicle and really need to get this sorted, I have a new dual mass flywheel and HD clutch from LOF sitting in the garage so just need to book it in. Then I just have the tunnel insulation to sort out.. TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #1057624 17th Jan 2025 7:09am
Page 3 of 3 <123
