Home > Maintenance & Modifications > sound proofing TDCI
Page 1 of 3 123>
LR90XS2011
sound proofing TDCI
I have searched on here and Googled and have found loads on sound proofing and Dynamat appears to be the preferred option.
Can those that have sound proofed their defenders themselves please help me out and tell me what you used, which panels and the real word results you achieved.
Also if you have used alternative brands how much success did you have.
What I would like is a general noise reduction so I can chat at higher speeds 60-70. DEFENDER 90 TDCI XS,
Post #946442 21st Mar 2022 10:40am
Mdm
I use noico but any of the other decent brands seem to have good results.
At the end of the day you still have the same engine and running gear.
plus the same glass, so you will alwyas get some noise transmission.
We have done partial cover to full cover and there is a small difference in noise levels but only if you have a noise meter to measure it.
carpet or rubber mats on top sure helps.
as does side panels on a hardtop.
Post #946445 21st Mar 2022 10:48am
I've had a lot of success with Silent Coat, which appears to be an identical but cheaper product to Dynamat, and generic self-adhesive closed cell foam in both my current 110...
Soundproofing Part 1 - Roof and Rear Load Area
Soundproofing Part 2 - Rear Door
Soundproofing Part 3 - Drivers Door
...and my old 90:
Headlining and Roof Sound Proofing
Rear Tub Sound Proofing and Rear Seats Part 1
Rear Tub Sound Proofing and Rear Seats Part 2
There's still more work to do on the 110 but that already done to the roof and rear has made such a difference that the rest has become less of a priority. Darren
Post #946449 21st Mar 2022 11:11am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I used Dodo products on mine. Very similar to the silentcoat stuff, but slightly better value.
I got mien from here: https://www.deadening.co.uk/collections/dodo-mat. No affiliiation, but I've used them for years and always been pleased with the service & products.
My 110 is a work in progress, but so far I've done:
Roof
Front Doors
Middle row floor.
On the roof and doors, I applied:
1 or 2 coats of the Dodo mat DEADN matting
6mm Dodo Super Liner (self adhesive closed cell acoustic foam)
On the floor I also added a layer of Mass Loaded Vinyl.
this one:
https://www.deadening.co.uk/products/dodo-barrier-mlv-2-5m-roll
Next on my list are:
Rear load space/floor
Rear Wheelboxes
Front bulkhead and floorpans. - Dash out!
Bonnet
I'm really looking forward to doing the read load space as i think this will make a lot of difference, especially if I do the wheel boxes. Mine only has rubber mats in the back, so I'll need to carpet (or similar) if I choose to do the wheelboxes.
Most of the above will get the same treatment as previously mentioned, but the bonnet will also get a bonnet liner added. Hopefully this (combined with the bulkhead stuff) will help keep some of the transit noises in the engine bay and out of the cabin!
There is a project landrover on their site too, some info here: https://www.deadening.co.uk/pages/project-landrover
As modifications go, I've found sound deadening quite rewarding. Easy enough to do, can be done in small stages depending on what time you have available, and you get to notice the impact of each bit that you do.
You certainly get through the products though, I thought I'd ordered enough to do everything, and I'll certainly need to get some more soon.
Post #946451 21st Mar 2022 11:35am
Avelingporter
I also used silent coat. Then on top was 10mm foil backed closed cell foam. The silent coat does the noise, the foam thermal insulation. Together brilliant. My TDCi 90 hard top is more car like now, well sort of, from a sound point of view. Make sure you also do the roof inc over the front. The noise from the roof just above your head is a noticeable drop after adding the silent coat. I got all my material from deadening.co.uk.
Post #946452 21st Mar 2022 11:38am
Guinness
I found a youtube video which shows the decibel levels before and after intensive soundproofing. It also shows what brands and types they use and where, it's very comprehensive. At the end of the day, it reduces the noise level by 10dB (take values with a pinch of salt), and bearing in mind this is a logarithmic scale, it is a huge amount. This is what I intend to follow when i eventually get round to soundproofing!
&list=FLN0AQzkPvgRZ2DGTMb8PG2Q&index=2&t=471s&ab_channel=Audiofile-Incar
Post #946453 21st Mar 2022 12:05pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
I used the pre-cut Dynamat kit for my 110 (ordered from LR Centre) and its a very handy way to do it.
More expensive than having it in rolls, but makes the job faster and easier while still covering what needs to be done. It makes a pretty dramatic difference in sound levels, but you do get used to the reduced sound almost immediately. Roaming around ๐Ÿ‡ณ๐Ÿ‡ด๐Ÿ‡จ๐Ÿ‡ญ
Post #946466 21st Mar 2022 1:52pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Things like dyna mat silent coat are designed to add weight to the panel stop the resonance of the panel they dont stop the travel of sound ie from the engine bay or tyres unless they are coupled with something like an acoustic foam.
I used TECSOUND SY50 which is a mass adding acoustic barrier so it does both stops air bourne sound and resonance. I did the footwells and lower bulkhead as well as the seat box and the difference was remarkable
Post #946488 21st Mar 2022 4:01pm
LR90XS2011
All
thanks for the updates brilliantly helpful as always, fancy doing this myself will let you know how I get on in due course
all the best DEFENDER 90 TDCI XS,
Post #946492 21st Mar 2022 4:08pm
Magoyo
Argentina 2009 Defender 110 Puma 2.4 HT Corris Grey
hi, i did almost the same things you mention here, and made one thing that i read in an old post here, that improved a lot the sounbd proofing; in a very close night, I turned on a very powerful searchlight inside the truck, and looked outside for any beam of light, and i found many little places, especially in the door seals, and in the boxes under de seats, were i could improve even more the sound proofing.
I take this opportunity to ask a question, I have a 2009 Puma, and apparently it has a good roof, but I have no idea if it comes with good insulation inside, and I don't want to disassemble it to see; Does anyone know how is the insulation on the ceiling in this model?
Magoyo
Post #946582 22nd Mar 2022 12:46pm
Snowy90
i dont think there will be any sound insulation, my 2008 hasnt got anything other than the roof lining, thats my next job.
Post #946588 22nd Mar 2022 1:02pm
This is correct. It's bare metal above the roof lining. Darren
Post #946593 22nd Mar 2022 2:42pm
Magoyo
thanks ยก, now in my list "to do" , but I admit that I am a little afraid of disassembling the roof
Post #946601 22nd Mar 2022 3:40pm
Snowy90
Its very simple to be honest, if you have the side mouldings around windows etc they just pull off to allow the headliner to drop down.
usually the christmas tree plastic fixings get chewed up so probably worth getting some spares
Post #946603 22nd Mar 2022 3:45pm
Magoyo
Thumbs Up i will start watching youtube videos
Post #946606 22nd Mar 2022 4:04pm
Page 1 of 3 123>
