Home > Puma (Tdci) > Heated windscreen - normal operation? |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 796 |
Assume the heating elements have failed? Mine did on my Td5 Discovery and it only heated patches, like yours. New windscreen solved that problem. BORG - Bucks & Oxon 4x4 Response Group
12th Jan 2025 10:17pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2263 |
Time for a new screen. A new screen will clear a heavy frost in 5 minutes.
Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey Last edited by Mo Murphy on 13th Jan 2025 8:25am. Edited 1 time in total |
13th Jan 2025 6:10am |
C90 Member Since: 19 Nov 2024 Location: Essex Posts: 27 |
Mine does exactly this too! ha. Let me know how you get on with the new screen and the damage £. Thanks! |
13th Jan 2025 7:28am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17505 |
It is only normal when the screen is fubar, as others have noted, time for a new screen. What you need ideally is a huge stone chip or a crack in the swept area, since that would legitimately allow you to exercise the windscreen repair provision of your insurance (which sadly almost certainly won't cover element failure). |
13th Jan 2025 10:44am |
mptzs90 Member Since: 24 May 2024 Location: Kent Posts: 29 |
Thanks all! Wanted to check this wasn’t expected first… I’ll go dig into what a replacement looks like
14th Jan 2025 10:17pm |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 129 |
As noted, probably a screen required, BUT, check it is getting power first. There are fuses and relays in the system.
15th Jan 2025 12:05am |
The fact that a narrow band is clearing correctly would suggest in this case that the screen is getting power.
15th Jan 2025 9:02am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6627 |
Mines getting like this, about 40% of it working. New screen needed soon 1988 90 Td5 NAS soft top
2015 D90 XS SW |
15th Jan 2025 9:09am |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 162 |
It’s amazing how much damage a good belt to a centre punch can do…. |
15th Jan 2025 8:10pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3340 |
Mine too. Only the left hand side of the screen demists. WARNING. This post may contain sarcasm. |
15th Jan 2025 8:20pm |
