Home > Puma (Tdci) > Heated windscreen - normal operation?
mptzs90
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Is this normal for the puma heated windscreen? I left it on for maybe 5-8 minutes before i gave up and started scraping. Only saw this center line and then a couple of other faint melting lines come through. How quickly should I expect it to start clearing the ice? There wasn’t a lot… took less than a minute to scrape the whole thing.
Post #1057195 12th Jan 2025 9:37pm
mini Anaconda
Assume the heating elements have failed? Mine did on my Td5 Discovery and it only heated patches, like yours. New windscreen solved that problem. BORG - Bucks & Oxon 4x4 Response Group
Post #1057199 12th Jan 2025 10:17pm
Mo Murphy
Time for a new screen. A new screen will clear a heavy frost in 5 minutes.
50 Shades of Pennine Grey
Post #1057216 13th Jan 2025 6:10am
C90
Re: Heated windscreen - normal operation?
Mine does exactly this too! ha. Let me know how you get on with the new screen and the damage £.
Thanks!
Post #1057218 13th Jan 2025 7:28am
mptzs90 wrote:
Is this normal for the puma heated windscreen? ...
It is only normal when the screen is fubar, as others have noted, time for a new screen.
What you need ideally is a huge stone chip or a crack in the swept area, since that would legitimately allow you to exercise the windscreen repair provision of your insurance (which sadly almost certainly won't cover element failure).
Post #1057237 13th Jan 2025 10:44am
mptzs90
Thanks all! Wanted to check this wasn’t expected first… I’ll go dig into what a replacement looks like
Post #1057406 14th Jan 2025 10:17pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
As noted, probably a screen required, BUT, check it is getting power first. There are fuses and relays in the system.
Post #1057414 15th Jan 2025 12:05am
The fact that a narrow band is clearing correctly would suggest in this case that the screen is getting power.
Post #1057429 15th Jan 2025 9:02am
Martin
Site Admin
Mines getting like this, about 40% of it working. New screen needed soon Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1057430 15th Jan 2025 9:09am
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
It’s amazing how much damage a good belt to a centre punch can do….
Post #1057492 15th Jan 2025 8:10pm
Zed
Mine too. Only the left hand side of the screen demists. WARNING.
Post #1057493 15th Jan 2025 8:20pm
mptzs90
Finally getting round to sorting this and I think the insurance (NFU) will cover it… using one of Autoglass or national windscreens. I’d assume these are roughly equivalent… searching here I’ve mostly found older threads on them but I’ll keep looking. Also sounds like it’s worth replacing the seal with a genuine one at the same time…
https://www.lrparts.net/lr056278-windscree...-2016.html
These seem to be unbelievably expensive (137 vs 9.50)! Definitely worth using genuine vs aftermarket?
Post #1060212 11th Feb 2025 9:56am
My local independent windscreen specialist told me when I last had a new screen fitted that originally the genuine seals were significantly superior to the aftermarket ones, being a different section which sealed better. However the more recent (post c.2014) seals were exactly the same as the aftermarket ones and had been "value engineered" or more likely re-sourced and that they were subsequently no better than aftermarket, just massively more expensive.
He recommended not changing an original seal in good condition since a new one was less likely to afford a good seal, but if the original seal had perished then an aftermarket was much better value that a new genuine seal.
I still have the original 2007 seal on my Defender but it is perished and cracking especially round the corners and works hard to maintain a high level of humidity and wetness in the cab. When I next need a new screen it will definitely be replaced.
Post #1060214 11th Feb 2025 10:19am
mptzs90
That’s helpful - thanks. I’ll see what the installer has to say about it. Mine is a Sept 2014 vehicle so I could be either side of the good/bad seal line …
Post #1060215 11th Feb 2025 10:21am
jonny
I swapped a non-heated screen for a heated one - I bought a heated screen and seal from VGS and got one of the local fitters to install it for me.
When he came, he said that he could have supplied and fitted for a similar cost to the VGS screen alone (£150 odd, a few years ago), and that the quality of seals is extremely variable. He didn't really like the look of the VGS supplied seal for some reason (too much slack or not enough?) and would have preferred to supply his own. He did fit it and it was fine from then on though.
It may be worth ringing some local fitters, especially if there's excess and implications to claiming on insurance come renewal time - you may have to declare a windscreen claim.
Post #1060225 11th Feb 2025 11:35am
