Home > Puma (Tdci) > Making a Puma engine last 200k
Page 2 of 5 <12345>
Ianh
I’m pretty sure Blackwolf is still on his original injectors in his 2.4 with circa 270k miles on it.. I’m sure if he spots this post he will confirm.
For me in my 2.2, I run a bottle of Forte Diesel Specialist Injector Cleaner (via the fuel filter and rest in tank) through the injectors once a year. Using milliner ecomax each time I fill with diesel. Keeps injectors and fuel system nice and clean.
Post #1057343 14th Jan 2025 11:58am
My injectors have never (yet) been out - original injectors and seals, 279,000+ miles.
The only things that have been replaced repeatedly are VCVs and clutches, although to be fair the most recent clutch is now approaching 150k miles. In 2007 you were lucky to get 3k miles from a Puma clutch.
Post #1057346 14th Jan 2025 12:22pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
To get 200K from my Ford Duratorq Puma engine, I do like all the Transit vans with Ford Duratorq Puma installed :
I drive long distance, no tuning and I follow the service schedule
Nobody does replace injectors in Transit vans, too.
Post #1057351 14th Jan 2025 1:45pm
My situation is basically the same as Blackwolf, only mine is on quite a lot less miles.
I try and avoid replacing some parts unless they need to be, as you can just keep going with that and replaced perfectly good items for no reason and at cost.
Occasionally it can pay to replace something so it has even longer service life.
But as I mentioned, it just wasteful to replace parts for the sake of it, there are a few items that are worth it though.
I’m not quite sure what to make of replacing the timing chain and guides, I’ve had it mentioned before but equally garages would.
The VCV is quite common, presumably I think it’s just wear, but is sensitive to contaminants going in like water, what is annoying is it might not be performing that well for a while, but not so badly as you’d notice. It’s a shame it isn’t covered by diagnostics directly, as then you could check its performance.
You can check pressures down the line, but that isn’t always particularly conclusive. Chillin In The Backwoods🇬🇧🇺🇸
Post #1057386 14th Jan 2025 6:57pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Just to add to mix, while the 2.4 is a fine engine, anything you buy is going to be old, 12 years+. You will probably need to redo consumables such as hoses, belt/idlers/tensioner, water pump, brake/clutch masters, flex-lines, etc. These things simply time out even with low miles.
Post #1057415 15th Jan 2025 12:13am
BrickBox
As above. Intercooler/radiators/boost pipes/coolant pipes even on the youngest Defenders are coming up for 10 years old. So expect to need to do consumables such as brittle pipes etc. 2008 2.4 110 Utility Station Wagon XS.
Post #1057423 15th Jan 2025 7:18am
Grenadier
For those of you who've mentioned it, what thoughts on the engine/injector cleaning fluids?
Do they work? Worth the money?
My 2.4 is now at 110k and I'm wondering what would be some good maintenance or clean up at this age? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1057467 15th Jan 2025 5:14pm
Ianh
Forte Diesel Specialist Injector Cleaner (via the fuel filter and rest in tank) Is VERY good, if used once every year. I’ve used it on several vehicles that have done a lot of miles on original injectors and they have always benefited from its use.
Post #1057470 15th Jan 2025 5:22pm
I use millers Diesel standard dosage in the tank 99% of the time, with the odd time I might not use it but very little.
I tend to use 25ml to 25L most, but you can use 50ml to 50L as well, so long as it’s dosed accurately as possible it’s fine.
Helps keep injectors cleaner, MPG, helps keep diesel bug at bay etc.
You can use it double dose like 1 shot like Forte presumably?
But Millers you use standard dose constantly, effectively it’s running on super diesel all the time, you just fill up with standard diesel and it adds lubricity and a few cetane numbers.
It’s the only additive I trust, many other members on here use it as well. Chillin In The Backwoods🇬🇧🇺🇸
Post #1057471 15th Jan 2025 5:27pm
Grenadier
I'll try and find Millers or Forte, check them out. Bardahl is the quality brand around here.
Given, to my knowledge, it's never had an additive before (save buying Total Excellieum) would it be worth chucking in a full system cleaner/scrubber like this first:
https://english.bardahl.fr/en-us/our-produ...aner-500ml Monsieur Le Grenadier
Post #1057479 15th Jan 2025 6:09pm
Ianh
Not all clearers are the same. Forte is good and available on french bay of e.
Best is to fill fuel filter with it, then rest in tank ( lower tank level the better so it’s less diluted) , go for a 20 minute drive and it should have run through all the fuel system inc injectors.
Then get the millers ecomax for regular use when filling up
Post #1057491 15th Jan 2025 7:46pm
Grenadier
Thanks for the tip, will track some down today. Thumbs Up Monsieur Le Grenadier
Post #1057512 16th Jan 2025 7:22am
Julie
If you bought Premium Diesel with U.S. standard Diesel specs (i.e. containing injector cleaner), it would help. Injectors suffer from short distance trips / cold engines.
Additif cannot work since quantity is far too small.
Don't expect too much from it. If the cleaning effect was too strong, it would ruin EGR etc.
Post #1057534 16th Jan 2025 12:40pm
I tend to go by the general rule of thumb no to mix these things.
So if you use premium / super diesel use that only.
If you use a product like Millers use that only with standard diesel.
Not mix standard or super fuel, and not mix the additive with others and stick to its standard dose.
If you do have to go without the additive, which can rarely happen, I just use the standard diesel,
It’s best to under do it, than over do it, this is just what I do.
I always use Millers, but Forte and Wynn’s are supposedly good.
I just personally wouldn’t mix them, if you did do what Ian mentioned you could but you’d want to run the fuel down to very little of one type, so that the vast majority is flushed out.
I use the Millers because it’s been verified by diesel techs, and plant machinery techs to keep engine internal components in good stead.
It also saves faffing around trying to find premium / super diesel, some places don’t have any.
Super is only really regular spec diesel with additives added by the supplier, whatever that may be.
And that’ll likely be Eco benefits rather than anything else, perhaps not so good for the engine. Chillin In The Backwoods🇬🇧🇺🇸
Post #1057537 16th Jan 2025 12:59pm
Grenadier
Thanks Custom90.
I was really looking for a 'forced' clean. I try my best to use Excellium, so I tend to get all the additives, but not always possible. This is more about giving it a thorough clean much as IanH has suggested, and then good fuels through the year. Monsieur Le Grenadier
Post #1057549 16th Jan 2025 2:21pm
Page 2 of 5 <12345>
