Home > Maintenance & Modifications > Power Steering Hose Thread (td5) (om605 conversion) |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1632 |
Measure them?! I’ve tried pirtek and a few other suppliers in the past, but haven’t had much success as they’re not a standard type fitting they said.
7th Jan 2025 12:21am |
DR.Pepper Defender Member Since: 06 Jan 2025 Location: Yeovil , somerset Posts: 5 |
Unfortunately I havnt got a td5 pump or fitting, and it’s bizarrely hard to find any proper info on sizes. Many defenders.....
Many series.... Many Range Rovers... Got a problem.... |
7th Jan 2025 12:44am |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 342 |
M16x1.5 rings a bell.
I had a high pressure hose made for my build. It only required that and a banjo fitting for the Pump on the 1UZ. 4.0 V8 Defender 90 My Instagram |
7th Jan 2025 6:44am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8102 |
From memory a 200tdi hp hose fits a 4bolt and m57 pa's pump. Not sure on sizes though. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Jan 2025 6:47am |
Brilliant much appreciated, I will get some fittings and see what I can do then.
Thanks all Many defenders..... Many series.... Many Range Rovers... Got a problem.... |
7th Jan 2025 3:06pm |
