![]() | Home > Maintenance & Modifications > Power Steering Hose Thread (td5) (om605 conversion) |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Measure them?! I’ve tried pirtek and a few other suppliers in the past, but haven’t had much success as they’re not a standard type fitting they said.
DR.Pepper Defender Member Since: 06 Jan 2025 Location: Yeovil , somerset Posts: 6 ![]() ![]() ![]() |
Unfortunately I havnt got a td5 pump or fitting, and it’s bizarrely hard to find any proper info on sizes. Many defenders.....
Many series.... Many Range Rovers... Got a problem.... |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 343 ![]() ![]() ![]() |
M16x1.5 rings a bell.
I had a high pressure hose made for my build. It only required that and a banjo fitting for the Pump on the 1UZ. 4.0 V8 Defender 90 My Instagram |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
From memory a 200tdi hp hose fits a 4bolt and m57 pa's pump. Not sure on sizes though. Cheers
Brilliant much appreciated, I will get some fittings and see what I can do then.
Thanks all Many defenders..... Many series.... Many Range Rovers... Got a problem.... |
