Page 1380 of 1382 <123 ... 1379 138013811382>
Caterham
Black Puma wrote:
Fitted brand new SVX Recaro's, and rubber mats under seat boxes. Between Christmas Lunch and Dinner...
Merry Christmas everyone!
they weren't mail order from the UK were they?
if so, do you mind sharing the details? Thumbs Up Thumbs Up
(ps. looking good). Mr. Green
Post #1056236 3rd Jan 2025 7:39pm
revd
Fired up the Eberspacher for the first time
Just need to tidy the cables and refit the cubby box
Post #1056395 5th Jan 2025 5:52pm
Changed the oil in the transfer box, gearbox yet to do soon. Very Happy GBR
Post #1056402 5th Jan 2025 6:18pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Oops duplicate post.
Post #1057068 11th Jan 2025 6:06pm
Scotm
5 hours in freezing temperatures replacing seized wiper spindles today.
Post #1057069 11th Jan 2025 6:06pm
landy andy
Brave or desperate?
It’s not the weather for that sort of fiddling. Well done for getting it sorted. Thumbs Up
Post #1057070 11th Jan 2025 6:08pm
Scotm
Desperate - other mode of transport has summer tyres and not pleasant to drive in current conditions.
Post #1057072 11th Jan 2025 6:10pm
landy andy
I thought that might be the case Rolling with laughter Rolling with laughter
Post #1057074 11th Jan 2025 6:11pm
Possible 5% off, on orders over £50 on eBay code. Might work up until 31/01/25
Redemption Code: SWEET5
Wink GBR
Post #1057083 11th Jan 2025 7:05pm
excossack
At the weekend I had planned on swapping the steering drop arm and replacing with a new one to try and resolve some play in the steering.
Bent the tab washer back and the nut felt only just tight. Sad
I undid the nut and removed the lock washer and beat it flat to reuse as I could not find my spare.
This time to make sure the steering arm was fully home, I used a socket and a hammer to try and drive the arm further on the splines.
On with the washer and on with the nut. The torque was 176nm, so I did the nut up to this and then torqued up to 180nm to make sure and then bent the washer over.
Also re-tightened the nut for the ball joint onto the steering arm. A quick drive and it felt better.
Checked oils/water/screen wash/replaced rear wiper blade and greased propshaft nipples. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1057257 13th Jan 2025 2:18pm
Yesterday, I changed the gearbox oil, and fitted Xeng magnetic filler and drain plugs.
The original hex key drain plug was definitely 50NM, I think it is too tight I managed to get it out, but you’ve got to be sure the hex key is fully home and in there so it doesn’t attempt to round out!
35NM is much better I think.
Were all of the factory plugs Hex key type on the MT82? Or was there some that was torx, perhaps I’m just thinking I’ve read that before.
The Xeng mag plugs are a flanged hex head bolt, thr original LR ones aren’t mag and are a female hex key.
I also lubed the transfer box linkages whilst under there, plus more to do.
Pretty much a lot of it is similar things to what Excossack mentioned in his last sentence. Very Happy GBR
Post #1057259 13th Jan 2025 3:10pm
excossack
After tightening up the steering bolts the steering feels a lot better and less vague.. Lets see how it goes. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1057547 16th Jan 2025 1:56pm
revd
Play is progressively worse as you approach either full left or full right lock - this is the way the steering box is designed. Adjust for play in the dead ahead position - you might have to centre the steering wheel and reset the track rods - I had a LR pal do mine on a Saturday morning - cost me a case of beer
Post #1057735 18th Jan 2025 12:45pm
Joe22
 2004 Defender 110 Td5 CSW Tonga Green
Fitted the rear door gas strut today.. 15 min job, excellent mod at around £30! Mr. Green
Post #1057785 18th Jan 2025 9:04pm
pistonfields
Switzerland
was getting sick of my phone overheating in the winter with hot air blowing against it.
3d printed. A first prototype, hence in red. Attached with double sided tape. Will adjust the outlets to face a tad more to the windscreen as the topmost part of my phone still gets some hot air. Didn't want to just block the outlet and it'll prevent my shoulder from freezing in the summer too.
Post #1057793 18th Jan 2025 10:11pm
