![]() | Home > Td5 > Defender TD5 2009 Power loss |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1182 ![]() ![]() ![]() |
So you changed the MAF and the reading is not charging? Sounds like the MAF is no good, which from what I understand is a common issue with aftermarket cheap units.
But the MAF is not doing much on the Td5. Probably more likely a turbo pressure issue, or many things combined |
Northern lad Member Since: 17 Mar 2024 Location: Saddleworth Posts: 18 ![]() ![]() ![]() |
Thought about another MAF. However triedanother working one and no change. Also the voltage readings were from when the three pin plug was disconnected as well as connected. Turbo pressure lifts when the engine takes load. Photos taken at idle.
Newlandy Member Since: 01 Apr 2024 Location: Gauteng Posts: 9 ![]() ![]() ![]() |
I had a similar intermittent problem. I found that the wiring from the AAP sensor had frayed inside the black cable covering, not sure what it's called. I peeled it all the way back to where the MAF wires join the loom and fixed the wiring. Problem solved.
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 222 ![]() ![]() ![]() |
Have you got continuity between MAF plug and the ECU plug (pin 20 on the red connector)?
If the MAF reading isn't changing from 4 then the issue must be MAF or its wiring. Faulty MAF does make them feel gutless. 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Thanks Hazza, next task. Have been busy with work when I get a minute. Will let you know how I get on.
andylee Member Since: 29 Jun 2016 Location: South East Posts: 98 ![]() ![]() |
Probably worth double checking all the intercooler hoses and fittings and check the intercooler itself hasn't split...
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
Check that the turbo waste gate is not seized.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 873 ![]() ![]() ![]() |
I have to ask - Do you have a Defender Puma with a TD5 engine installed or the standard 2.4 Ford Puma engine?
Jim |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2200 ![]() ![]() |
If you have a nanocom you can download the ROW spec maps from Empire Tunings website which removes the MAF sensor. Its a poor and expensive sensor that isnt needed. IF this is a TD5 that is.
It should run better with it disconnected. If there is no change with it disconnected then your problem isnt the MAF sensor. Instagram @defender_ventures Empire Tuning - Agent |
