Home > Td5 > TD5 Performance Intercooler causes Christmas day disaster
LANDROVER
A job on my list of jobs...
I have a large intercooler, it's been on the 110 for years but I've never been happy with it's fitment.
I replaced the coolant top hose and the replacement was not a one piece one, and it swiftly touched the aux belt. So I replaced and the replacement also has managed to do the same.
I think its because the massive replacement intercooler sits a bit more towards the engine and pushed the radiator also further back.
Does anyone know of any brackets/mounts that address this issue to save me fabricating something.
Thank you.
Post #1042699 13th Aug 2024 10:55pm
bankz5152
What intercooler is it?
I would suspect it's not fitted correctly, the mounts into the wings have a fair bit of play in them for adjustment.
Post #1042706 14th Aug 2024 6:57am
LANDROVER
My intercooler position
My brother's position
I'm not sure on intercooler. It's been on it since I bought the 110. It's bigger than an original one but I see no maker's name.
When I compare it to another it has forced the radiator back toward engine.
The coolant pipe for thermostat has touched the aux belt.
Christmas day was a disaster as it split and coolant went onto belt causing it to slip. Luckily I noticed something was wrong. I hope it didn't do any damage 😔
I'm not sure if I should try and move the intercooler brackets.
Cut and weld them forward.
Buy a new intercooler and coolant pipes..
I need to sort it asap so got to work out the best route.
Just seems strange if the intercooler is wrong but I guess anything could happen been fitted.
Post #1055663 26th Dec 2024 6:09pm
LANDROVER
I just uploaded pictures.
I'm not sure what the intercooler is.
Post #1055664 26th Dec 2024 6:14pm
bankz5152
Is it the original engine?
Looks like a D2 top house
You need to take the cowling off so we can see how its mounted.
Its 4 screws
Post #1055667 26th Dec 2024 7:32pm
LANDROVER
Thank you for replying.
As far as I know original engine .. though something I don't know.
I've had it a few years now but no history.
Top hose is a replacement one.
The original was a one piece type but I replaced but when I removed it have been cut and joined if I remember right.
Are the original intercoolers the same as tdci ones?
My friend changed his to upgraded ones so he might have a spare.
Post #1055671 26th Dec 2024 11:11pm
rustandoil
As suggested, I think we need a couple more pictures with the cowl off.... The fan must be very close to the rad?
Post #1055677 27th Dec 2024 8:24am
jst
I would suggest the diagnol supports ares still fitted meaning it's mounted further back.
Or its an incredibly thick intercooler.
If leaving it as it currently is that top hose needs shortening to eliminate the constriction on the 90 bend. Presumably a longer hose from stat is needed as its pulled further back and is taking direct, shorted path to reach stat housing and that interacts with the fan. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1055685 27th Dec 2024 9:53am
LANDROVER
I will look later as I had to leave it elsewhere.
I cut the top hose to make it clear the aux pulley but the hose leaked on on of the bands that crimp it on.
So I need to find a new hose.
I'm hoping to ring round and find some parts today to get it back together and running.
Post #1055692 27th Dec 2024 10:25am
LANDROVER
Yes it runs very close.
I have cut fan shroud as it used to.rub on acoustic cover.
Post #1055693 27th Dec 2024 10:27am
LANDROVER
Diagonal support's?
I will check. From what I could see without stripping it out to.look was the brackets which attach to the wings have the locating point for intercooler.
That position makes it sit back and radiator is fastened tonite making it also back.
The brackets on the wings have elongated holes but this is like 2" back from where it should be.
If a puma intercooler is the same I might be able to grab one from a friend to fit instead as he swapped his out for aftermarket ones.
Post #1055694 27th Dec 2024 10:31am
htb2
Wales
Puma and TD5 intercoolers are the same.
Post #1055700 27th Dec 2024 12:56pm
jst
Diagonal support's?
If a puma intercooler is the same I might be able to grab one from a friend to fit instead as he swapped his out for aftermarket ones.[/quote]
The brackets must be fitted further back than std either for a very thick, ie double normal upgraded intercooler thickness or to allow fitment with the diagnol supports still fitted.
Cut or not the top hoses is too long hence the resection on the bend. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1055728 27th Dec 2024 4:27pm
bankz5152
I reckon the rad pack has come out of its mounts and touching the fan because of loose fittings on the slam panel.
Post #1055729 27th Dec 2024 4:35pm
LANDROVER
Post #1055829 29th Dec 2024 1:03pm
