![]() | Home > Td5 > TD5 Performance Intercooler causes Christmas day disaster |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2200 ![]() ![]() |
What intercooler is it?
I would suspect it's not fitted correctly, the mounts into the wings have a fair bit of play in them for adjustment. Instagram @defender_ventures Empire Tuning - Agent |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 216 ![]() ![]() |
![]() Click image to enlarge My intercooler position ![]() Click image to enlarge My brother's position I'm not sure on intercooler. It's been on it since I bought the 110. It's bigger than an original one but I see no maker's name. When I compare it to another it has forced the radiator back toward engine. The coolant pipe for thermostat has touched the aux belt. Christmas day was a disaster as it split and coolant went onto belt causing it to slip. Luckily I noticed something was wrong. I hope it didn't do any damage 😔 I'm not sure if I should try and move the intercooler brackets. Cut and weld them forward. Buy a new intercooler and coolant pipes.. I need to sort it asap so got to work out the best route. Just seems strange if the intercooler is wrong but I guess anything could happen been fitted. |
I just uploaded pictures. I'm not sure what the intercooler is. |
Is it the original engine?
Looks like a D2 top house You need to take the cowling off so we can see how its mounted. Its 4 screws Instagram @defender_ventures Empire Tuning - Agent |
Thank you for replying.
As far as I know original engine .. though something I don't know. I've had it a few years now but no history. Top hose is a replacement one. The original was a one piece type but I replaced but when I removed it have been cut and joined if I remember right. Are the original intercoolers the same as tdci ones? My friend changed his to upgraded ones so he might have a spare. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 804 ![]() ![]() ![]() |
As suggested, I think we need a couple more pictures with the cowl off.... The fan must be very close to the rad?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8192 ![]() ![]() ![]() |
I would suggest the diagnol supports ares still fitted meaning it's mounted further back.
Or its an incredibly thick intercooler. If leaving it as it currently is that top hose needs shortening to eliminate the constriction on the 90 bend. Presumably a longer hose from stat is needed as its pulled further back and is taking direct, shorted path to reach stat housing and that interacts with the fan. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I will look later as I had to leave it elsewhere.
I cut the top hose to make it clear the aux pulley but the hose leaked on on of the bands that crimp it on. So I need to find a new hose. I'm hoping to ring round and find some parts today to get it back together and running. |
Yes it runs very close. I have cut fan shroud as it used to.rub on acoustic cover. |
Diagonal support's? I will check. From what I could see without stripping it out to.look was the brackets which attach to the wings have the locating point for intercooler. That position makes it sit back and radiator is fastened tonite making it also back. The brackets on the wings have elongated holes but this is like 2" back from where it should be. If a puma intercooler is the same I might be able to grab one from a friend to fit instead as he swapped his out for aftermarket ones. |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 543 ![]() ![]() |
Puma and TD5 intercoolers are the same.
Diagonal support's? I will check. From what I could see without stripping it out to.look was the brackets which attach to the wings have the locating point for intercooler. That position makes it sit back and radiator is fastened tonite making it also back. The brackets on the wings have elongated holes but this is like 2" back from where it should be. If a puma intercooler is the same I might be able to grab one from a friend to fit instead as he swapped his out for aftermarket ones.[/quote] The brackets must be fitted further back than std either for a very thick, ie double normal upgraded intercooler thickness or to allow fitment with the diagnol supports still fitted. Cut or not the top hoses is too long hence the resection on the bend. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I reckon the rad pack has come out of its mounts and touching the fan because of loose fittings on the slam panel. Instagram @defender_ventures
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
