Those "strengthening" bars should either be removed of spaced off from the intercooler. Which then in turn will allow the rad and IC to sit further forward.
Thank you
I will try removing the bars
It looks like that it cannot move much because of the brackets the intercooler hooks into.
The brackets fastened to the wing look like that they are the limiting factor as they don't move much unless I'm mistaken
Currently swapping the stub axle as that keeps leaking..winter is the best time to do this I'm sure ❄️
29th Dec 2024 2:18pm
bankz5152
Those brackets have lozenges to allow for build tolerances
