Home > Td5 > Replacing sunroof seal |
revd Member Since: 20 Apr 2024 Location: England Posts: 153 |
Probably need this then; Sunroof Frame & Seal - AWR3321 - Genuine £604, from Rimmer Bros
20th Dec 2024 7:51am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 950 |
That is the correct part. Only the whole thing not just the rubber. 🤨. Pic your requested. 👇🏻
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
20th Dec 2024 1:51pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 628 |
I have found that the original seal for the twist handle sunroof is long lasting, usually what causes leaks is where the roof hasn’t been operated for six months over the winter, the seal can stick to the glass on the rear corners and when operated it lifts the seal out of the frame and unseats it; the seal will then not seat in the frame properly unless it is fed back into position in the frame by hand.
They can also leak from the roof to outer frame fitment, this seal is foam strip and can go flat and leak over time - the inner rubber / felt trim can be removed and the sunroof frame unscrewed (torx self tappers), the outer frame can then be lifted and bedded back down again on decent sealant. |
21st Dec 2024 7:37am |
johnnymarrsbarres Member Since: 03 Oct 2024 Location: UK Posts: 13 |
They specifically advertise that seal as being for the twist style sunroof, which is what I have. The text on LR Parts says: "Introducing the LRC10106 Weather Seal for the rotary handle style factory fit popup sunroof...Previously only available with the AWR3321 Sunroof Frame, this particular seal fits between the frame and the glass. It's specifically designed for the Defender's later rotary handle" But it seems to me anyway that it can only go in one way - and it does fit perfectly - but its design seems totally different to the OEM seal and means the glass can't fit properly. A bit of internet digging suggests this aftermarket seal (LRC10106) was made by TASC Automotive who also trade as the Bristol Sunroof Centre. I was about to email them and ask for some info but seems they went out of business in 2021! LR Parts weren't particularly helpful when I messaged them, so it seems I am up the creek. I don't fancy forking out 600 quid for a new sunroof if I can help it. |
23rd Dec 2024 4:00pm |
Damn! That sucks. It seems to me th da y of yo use new seal would curve down rather than upwards it would work🤷♂️ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
23rd Dec 2024 4:32pm |
