Home > Puma (Tdci) > Puma mileage, how long will the engine last? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
That is a lot of diesel!! 1982 88" 2.25 diesel
19th Dec 2024 10:16am |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 490 |
At least one member on here - L110 CDL - Clayton. 1983 110 automatic OM606 |
19th Dec 2024 11:44am |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 204 |
@Blackwolf
Whilst quite a lot of my Defender is younger than the vehicle as a whole, virtually all the engine and attached components are original - the injectors, timing gear, By Timing gear do you mean the timing chain etc? I was planning on getting mine replaced or at least inspected at the next service as it's now over 100,000 miles, if you are well beyond that point on the originals then I'm a lot less concerned Have you had to do any preventative inspections or maintenance to achieve this? Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
19th Dec 2024 3:27pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17501 |
Yes, I mean the timing chain etc., the front cover has never been off.
I've done nothing more than routine maintenance, but I drive sympathetically and don't do short journeys. The engine has also been de-EGRed and has a Provent fitted, both of which I believe substantially improve the likelihood of longevity. |
19th Dec 2024 4:06pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 508 |
Apparently, EGR and EURO spec do not influence longevity, since 50% on the list are factory spec whilst the rest is modified.
22nd Dec 2024 1:38pm |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 400 |
I've had every puma! From the earlier direct injection ones in transits right up to the last of them. I've had 2.4tdci transits with a couple hundred thousand miles with ease. I currently have a 2.2 with 224k on it. I had a 2.2 hole a piston with 50k on the vehicle I suspect this was due to a remap I'd usually drove the balls off it but I was experimenting with how much mag I could get out of it and it over fueled and holed this piston.
22nd Dec 2024 3:47pm |
revd Member Since: 20 Apr 2024 Location: England Posts: 153 |
From memory Next Meridien Puma was remapped |
22nd Dec 2024 4:39pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
The Next Meridian Defender Albatross was remapped when the replacement engine was fitted. I've been following their adventure from the start. Good YouTube viewing.
23rd Dec 2024 12:39pm |
