![]() | Home > Puma (Tdci) > Puma mileage, how long will the engine last? |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
https://oem.mann-hummel.com/en/oem-product...0-300.html
I was researching catch cans as I was considering fitting one to the 2.4 Puma. I e-mailed Mann-Hummel regarding their Provent2 unit. They advised me AGAINST fitting it as an after market installation. I know people do fit catch cans and I presume Mann-Hummel's reasoning against self installation will stand for all units not just their own. Here is the e-mail. Thank you very much for your interest in our products ProVent² is basically feasible for Diesel engines but it needs to be adjusted to the specific requirements of each engine type. Different parameters influence the performance and could, if applied wrong and not validated correctly, severe damage to your engine. Therefore we only supply this filter type directly to OEM´s and go through several development loops together with them. I am sorry to give you this negative feedback but in your case we are not able to support your inquiry. Mit freundlichen Grüßen Best regards Dominic Burgstahler Product Management HD&I Liquid filters So it is not just a matter of buying one, conjuring up the pipework and fixing it in place. Other factors need to be taken in to consideration. Seems to me that if factory fitted the ECU will be notified and the catch can integrated into the system 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
ScarboroughSeadog Member Since: 21 Jul 2022 Location: Scarborough Posts: 110 ![]() ![]() ![]() |
My 2.2 currently on 140K with no (engine) problems.
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 236 ![]() ![]() |
1st service since fitting a Provent, I always remove the MAP to clean - normally covered in black gunk, not this time totally clean 👍 got to be better not having that stuff go thru 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
I do not have the Provent fitted so both my 2.4 Pumas are standard. The MAF sensor is always clean when I check it. 1982 88" 2.25 diesel
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Minch90 did say MAP sensor not MAF sensor. The former gets gunked up, the latter doesn't, due to their locations.
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
lightning, IMHO with a higher mileage vehicle, it's not only the engine you have to be concerned with, it's the rest of the vehicle too, which has done the high mileage,..doors hinges seats, transmission bodywork etc etc. I'd be going for a low mileage unit every time, with a good owner/service history.
Pickles. |
Sorry about that. Funnily enough it is never too bad. I clean it every so often with a bit of diesel on a piece of kitchen roll. I just put the twist of kitchen roll with a bit of diesel on it through the plastic sides and twist it about and whatever dirt is there comes off. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 883 ![]() ![]() ![]() |
I have to disagree with that. In my opinion, you’re just paying a premium (almost double the price) for the mileage on the clock - to still have to replace components due to lack of use. I.e perished hoses, dried out bearings, cracked tyres etc. I’d rather the high mileage vehicle that will have had most the tired out items replaced. Saving half the money also lets you modify/customise the vehicle without any worry of devaluing it like you would a pristine, low mileage equivalent. 2008 2.4 110 Utility Station Wagon XS. |
So what you're saying is, don't fit the catch can, save the money, ruin the engine, with saved money fit a M57? My kinda thinking. Especially fitting a M57 for £200. Where do I sign up? ![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
I did say "start" of the engine fund! With interest rates as they are, your £200 could have increased to about £211.03 after ten years you need the new motor.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3480 ![]() ![]() ![]() |
![]() ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Indeed they are, which is rather disturbing when you have one with more than a quarter of a million miles on the clock. ![]() |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1678 ![]() ![]() ![]() |
Don’t you know that’s why you hoard engines…amateurs
