![]() | Home > General & Technical (L663) > Gap Diagnostic Tool working Activations |
SCL3 Member Since: 01 May 2024 Location: Metro Manila Posts: 2 ![]() ![]() |
Hello first time posting here, has someone unlocked the speed limiter on the new defender with the Gap tool? Have a long trip coming up about 800 km with long stretches of road in the Philippines and looking to get past the 209 kph on my defender. It's already piggyback chipped and with high flow intake and can easily get past 209kph.
Looking for an alternative to this activation offered at https://autosvs.com/en/product/l663-maximu...orrection/ using their own way and remotely using TeamViewer. Btw thank you for the activations posted and they do all work on my defender very useful dynamic mode and acc. Haven't gotten to park assist but will be trying soon. 2024 P400e SE Gondwana Stone Urban Pack |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 111 ![]() ![]() |
Deleted
Freddy801 Member Since: 01 Oct 2024 Location: Virginia Posts: 4 ![]() ![]() |
I have the same question. I am about to upgrade my screen to the 11.4" using the brackets from Powerful.co.uk and I am wondering if the next OTA update of Pivi Pro will auto detect my new screen size and change the screen display to the MY25 configuration.
Any ideas or is it a selectable option in the CCF? Thank you! |
Still shows start button as greyed out! Any one come up with a solution? Mine is a 2024 90 D350 HSE |
jlros Member Since: 06 Jan 2025 Location: new york, ny Posts: 1 ![]() ![]() |
Very strange, I have a 2024 110x and don’t have EUCD 140 on my tool list.
Any advice welcome.
nomud4me Member Since: 18 Jan 2025 Location: London Posts: 3 ![]() ![]() |
Hi everyone (three Defenders but absolutely brand new to this forum - thanks for being here)
Bought IIDtoolG4...updated firmware, registered / activated with my L663 90 First Edition (2021). Today I tried it for the first time...specifically changed ATPC from "HDC" to "HDC and LSPC", and Microphones to Two Microphones (Front Only). Then updated - waited for the update to complete (all ECUs, etc.). After update: - Emergency braking not working - Cruise control not working - Speed limiter not working - Parking sensors don’t seem to be working - Seen the car indicate a warning that it is in two wheel drive (and "beware of low traction") I drove the car around for 20 minutes or so - still no activation of ATPC. I fully locked the car / then unlocked again after 60 seconds (while still inside the vehicle). During that time, the Pivi screen was totally blank (expected) and the dashboard screen was blank - except there was a Red 'led type light' (located midway between top and bottom on the right hand side) of the dashboard screen, flashing on and off, and in the middle top of that screen, a "℗" illuminated in red. The only changes were to the ATPC and Microphones...and waited until the update was fully completed. Any thoughts on what I may have done wrong / what could have caused all this, before I make an appointment with a dealer to Service the vehicle and check out everything? Thanks in advance - anything appreciated. Best Mike L663 D90 First Edition (2021) 110 County SW Td5 (1999) 90 2.2 'Farm Yard!' (2014) |
Have you rebooted the pivi system? Press and hold the off/volume button for 20 seconds and it will turn off and reboot. Then lock car for 20 minutes. Should work then
Thanks for the rapid reply - will give that a go! Much appreciated. L663 D90 First Edition (2021)
Thanks Colin - that worked! Now the car will save me where my off-road skills fail me
![]() 110 County SW Td5 (1999) 90 2.2 'Farm Yard!' (2014) |
Reeboodro Member Since: 20 Jan 2025 Location: Louisiana Posts: 1 ![]() ![]() |
I still cannot get the auto start/stop feature to work.
Can 566 "enabled" with start/stop button pressed (yellow light on). Model year is a 2021. Have done this several times and restarted the PiVi. |
When I changed MultiCAN-890 Startup Logo
Mainstream Brand-based to SV Bespoke and it comes up on the start up screen. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3034 ![]() ![]() |
lt worked on my 2022 but some people have reported that it doesn't work on their Defender. |
ElectroGeek Member Since: 25 Jan 2025 Location: Texas Posts: 20 ![]() ![]() |
Has anyone found the CCF that will allow the doors to be locked when the Car is Running and the key isnt in the car?
Also has anyone found a way to disable to the Energy saver mode that kicks in after 15 min of idling and wants to turn the Eng off? Last edited by ElectroGeek on 28th Feb 2025 5:10pm. Edited 1 time in total |
