Home > General & Technical (L663) > Gap Diagnostic Tool working Activations
Page 2 of 2 <12
SCL3
Philippines
Maximum vehicle speed limit correction with Gap IITool BT G4
Hello first time posting here, has someone unlocked the speed limiter on the new defender with the Gap tool? Have a long trip coming up about 800 km with long stretches of road in the Philippines and looking to get past the 209 kph on my defender. It's already piggyback chipped and with high flow intake and can easily get past 209kph.
Looking for an alternative to this activation offered at https://autosvs.com/en/product/l663-maximu...orrection/ using their own way and remotely using TeamViewer.
Btw thank you for the activations posted and they do all work on my defender very useful dynamic mode and acc. Haven't gotten to park assist but will be trying soon. 2024 P400e SE Gondwana Stone Urban Pack
Post #1048200 10th Oct 2024 5:52am
sasa
Czech Republic
Re: Comparing with a working vechile
cfong02 wrote:
HI,
I am also struggling on the Defender, grey out 'Start' button during auto parking.
I have an L460 Range Rover with full specs and park assist; I to share my settings here:
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
MultiCAN-469 PDCAutoActivation
Standard: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
MultiCAN-602 PDC
Standard: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears)
You will notice that many Defender CCF settings were NOT enabled on my Range Rover, even though the Range Rover has full park assist. So I assumed we are looking at the wrong parameters in the Defender CCF?
ALSO, The last user memory in Defender (MultiCAN-566 MHLastUserMode) is not working on the Range Rover, I still have to manually turn off Auto Start/Stop
this setting for L460 is functional in Defender, I tested it today. However, of course, the whole setting was also originally. I didn't notice a difference...
Post #1051816 15th Nov 2024 10:31am
Colin68
Deleted
Deleted
Post #1052209 19th Nov 2024 4:10pm
Freddy801
United States
I have the same question. I am about to upgrade my screen to the 11.4" using the brackets from Powerful.co.uk and I am wondering if the next OTA update of Pivi Pro will auto detect my new screen size and change the screen display to the MY25 configuration.
Any ideas or is it a selectable option in the CCF?
Thank you!
Post #1052532 22nd Nov 2024 3:43pm
Colin68
Sticks999 wrote:
Hi has anyone managed to get park assist to work. I have entered all of the below and everthing is present but the Start button is greyed out.
Park assist settings
Activate Park Assist
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
Change to: With Park Assist Camera
Change to: With PDC Auto Activation menu
Standard: Not Supported
Change to: Default OFF configurable
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears)
• Needed 2 resets to PIVI for the app to appear in PIVI and a full car shut-down to clear the "Emergency Brake Assist Unavailable" error.
Still shows start button as greyed out! Any one come up with a solution? Mine is a 2024 90 D350 HSE
Post #1054731 15th Dec 2024 12:25pm
jlros
United States
Park Assist GAP IID
Very strange, I have a 2024 110x and don’t have EUCD 140 on my tool list.
Any advice welcome.
Change to: Fitted
MultiCAN-602 PDC
Post #1056511 7th Jan 2025 12:43am
nomud4me
Hi everyone (three Defenders but absolutely brand new to this forum - thanks for being here)
Bought IIDtoolG4...updated firmware, registered / activated with my L663 90 First Edition (2021).
Today I tried it for the first time...specifically changed ATPC from "HDC" to "HDC and LSPC", and Microphones to Two Microphones (Front Only).
Then updated - waited for the update to complete (all ECUs, etc.).
After update:
- Emergency braking not working
- Cruise control not working
- Speed limiter not working
- Parking sensors don’t seem to be working
- Seen the car indicate a warning that it is in two wheel drive (and "beware of low traction")
I drove the car around for 20 minutes or so - still no activation of ATPC.
I fully locked the car / then unlocked again after 60 seconds (while still inside the vehicle). During that time, the Pivi screen was totally blank (expected) and the dashboard screen was blank - except there was a Red 'led type light' (located midway between top and bottom on the right hand side) of the dashboard screen, flashing on and off, and in the middle top of that screen, a "℗" illuminated in red.
The only changes were to the ATPC and Microphones...and waited until the update was fully completed.
Any thoughts on what I may have done wrong / what could have caused all this, before I make an appointment with a dealer to Service the vehicle and check out everything?
Thanks in advance - anything appreciated.
Best
Mike L663 D90 First Edition (2021)
110 County SW Td5 (1999)
90 2.2 'Farm Yard!' (2014)
Post #1057738 18th Jan 2025 1:24pm
Colin68
Have you rebooted the pivi system? Press and hold the off/volume button for 20 seconds and it will turn off and reboot. Then lock car for 20 minutes. Should work then
Post #1057745 18th Jan 2025 2:57pm
nomud4me
Thanks for the rapid reply - will give that a go! Much appreciated. L663 D90 First Edition (2021)
Post #1057746 18th Jan 2025 3:01pm
nomud4me
Thanks Colin - that worked! Now the car will save me where my off-road skills fail me Smile L663 D90 First Edition (2021)
Post #1057751 18th Jan 2025 3:44pm
Colin68
Post #1057794 18th Jan 2025 10:14pm
Reeboodro
United States
Auto Start Stop
I still cannot get the auto start/stop feature to work.
Can 566 "enabled" with start/stop button pressed (yellow light on).
Model year is a 2021. Have done this several times and restarted the PiVi.
Post #1058074 20th Jan 2025 10:00pm
Page 2 of 2 <12
