Home > Td5 > 10p Constantly needing purge after head rebuild |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5747 |
You describing failed seals on the injectors. If you prime on first start all good for the day, and no problems then on, till next time you leave it for a period of time.
8th Dec 2024 10:19am |
IronKettle Member Since: 08 Dec 2024 Location: Lincolnshire Posts: 5 |
Damn!
Will I need to drain the oil to do the injector seals again? Is there a big difference between an aftermarket and OEM quality kit? |
8th Dec 2024 11:17am |
You don’t need to oil change. I would for the few ££ is costs though. I don’t think you are getting diesel into oil, you are getting combustion gases into the fuel line.
From my understanding yes a big difference in origin of parts apparently. But I fitted the kit supplied by Turners. They know their stuff. OE kit. |
8th Dec 2024 3:07pm |
tom1979 Member Since: 22 Nov 2021 Location: Bedfordshire Posts: 18 |
Was the kit from Turners the full top end kit? I cannot see just an injector seal kit on their site ------------- Defender 90 Td5 Discovery 2 Td5 Manual Discovery 2 Td5 Auto Range Rover Classic 300Tdi Bobtail Ranger Rover L322 M57 (and more- yes I have a problem!) |
8th Dec 2024 10:16pm |
There is a massive difference, even between was is advertised as genuine! The only ones worth fitting are the genuine seals that come in genuine packaging. Even the Britpart kits that are supposed to be genuine but packaged by them people have issues with regularly. Also make sure the injector bores are spotlessly clean and that everything is torqued correctly and checked. https://twinwoods4x4.co.uk/product/genuine...-packaged/ ------------- Defender 90 Td5 Discovery 2 Td5 Manual Discovery 2 Td5 Auto Range Rover Classic 300Tdi Bobtail Ranger Rover L322 M57 (and more- yes I have a problem!) |
8th Dec 2024 10:19pm |
Picked up a set of genuine seals from rimmer bros (they're fairly local to me) and the problem has gone! Starts up without issue now.
27th Dec 2024 11:59am |
revd Member Since: 20 Apr 2024 Location: England Posts: 151 |
Rimmers are a good source of genuine parts |
27th Dec 2024 12:12pm |
Since rebuilding the head I'm seeing a fair bit of coolant loss.
- I can't see any signs of hoses leaking. - There is no rise in oil level. - No mayo in the oil. - No visible oil in the coolant. - No smoke (outside of first start-up). - No loss in power. - Heater working fine. I'm really hoping the head gasket didn't instantly go / there is a crack in the head? Starting to really hate this truck ! |
3rd Jan 2025 11:18am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1632 |
Fuel cooler?
4th Jan 2025 1:49am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 629 |
Once I had problems with bubles in fuel. We added a piece of clear tube to fuel pipes commin to and back from engine, jus to clearly see the bubles there.
Also one big bad experience with Britpart - fuel filter head replaced, because original was corroded and broke. It was.working, but it was hard to purge the fuel system. After few days it was neede to purge again, again very hard. I have replaced both pastic valves from old head to the new, and it was perfect. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
5th Jan 2025 9:03pm |
