Home > Technical > Crank, no start
Frank Haddad
United Kingdom 2013 Defender 90 Puma 2.2 Adventure Yulong White
Crank, no start
2013 Defender that cranks a couple of revolutions then power is cut to the starter, can not find any info on it, I am in the U.S. and it was purchased from another country, therefore no dealer will even look at it.
Post #1053668 2nd Dec 2024 6:07pm
Ianh
Is your vehicle a 2.4 or 2.2 ? I suspect a 2.2 but wanted confirmation.
Have you a code reader to check and post DTC’s ?
With more info it will help narrow down the cause.
Post #1053671 2nd Dec 2024 7:14pm
Frank Haddad
2.2 and only code was P065B generator control circuit, I have taken it to be checked and the alternator is just fine and put it back in.
Post #1053673 2nd Dec 2024 7:55pm
Ianh
It could be an immobiliser issue. Do you have central locking and fobs ? Are they activating the central locking ? Has the red alarm light on IPAC been staying on ( not blinking) when you last started the vehicle. If so change the fob battery (CR2032) then re sync fob . Then see if vehicle will start. Noting fob should be on same key ring as key and only one fob in vehicle at any time.
Post #1053688 2nd Dec 2024 10:53pm
As above, it’s easily done, especially if the fob isn’t synced, the red immobiliser dash light must be off and not blinking before starting.
If it does, you just press unlock once on the fob, before starting.
Other than that, it could be the diode pack on the Alternator, was that checked? WeWillWin🇬🇧🇺🇸
Post #1053719 3rd Dec 2024 11:17am
Frank Haddad
There are no key FOBs and I have had the alternator checked and diode is fine.
Post #1053744 3rd Dec 2024 5:05pm
Frank Haddad
Could it be a crank or cam speed sensor? or something along the line?
Post #1053815 4th Dec 2024 5:59pm
Esben Kold
Denmark 2008 Defender 110 Puma 2.4 SW Galway Green
Do you own a nanocom? I would try and disable the active immobilizer.
Post #1053825 4th Dec 2024 7:17pm
Ianh
Yes it could be one of the sensors. Both are required for starting but only crankshaft sensor needed when running.
Post #1053998 6th Dec 2024 4:38pm
