Home > Puma (Tdci) > 2.2 Fog light not working |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1081 |
Should be working with head lights on, no need for engine running.
Have you checked for the "ECU" in the right hand side seat box? It's an electronic latch and I shouldn't give much trouble but maybe a loose connector? https://www.defender2.net/forum/topic63089.html |
25th Nov 2024 5:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20418 |
Is it incandescent i.e. has a holder and a light bulb and filaments or LED? $W33T $0U7H3RN $UG4R
25th Nov 2024 6:13pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 802 |
Have you got your Landie running with dipped beam headlights on when you test it?
Was it working before? Jim |
26th Nov 2024 3:38am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 496 |
Didn't come up while moving thé truck. I'm going to check the connectors in the right seat box. And mesure the ECU in the link. Now I'm in Africa - fog lights would be appreciated for mu return in January. Everything is orginal no mods but the truck tows. I've already separated the stuff to make sure that the fault ils not related to trailer ans its cables. I remember having had thèse probkrms before. I jusr changed the switch and everything worked fine. But the inside if the switch is i' perfect condition. |
26th Nov 2024 6:56pm |
Tried it with headlights switched on. Fog light has been working every 2 years for French MOT |
26th Nov 2024 7:12pm |
