Home > Puma (Tdci) > 2.2 Fog light not working
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi, my fog light doesn't work
What I exclude :
- bulb is fine + contacts in good condition
- 10A fuse is fine
- I opened + cleaned the switch. It's as good as new
- I tried with head lights switched on
But the yellow lamp on the switch doesn't come up
Tomorrow I'm going to try once more while truck is moving
Perhaps the ECU wants this information, too. But I doubt it.
Any more ideas what to check ?
Post #1052891 25th Nov 2024 2:52pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Should be working with head lights on, no need for engine running.
Have you checked for the "ECU" in the right hand side seat box? It's an electronic latch and I shouldn't give much trouble but maybe a loose connector?
https://www.defender2.net/forum/topic63089.html
Post #1052922 25th Nov 2024 5:43pm
Is it incandescent i.e. has a holder and a light bulb and filaments or LED? $W33T $0U7H3RN $UG4R
Post #1052928 25th Nov 2024 6:13pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Have you got your Landie running with dipped beam headlights on when you test it?
Was it working before?
Jim
Post #1052962 26th Nov 2024 3:38am
Julie
Didn't come up while moving thé truck.
I'm going to check the connectors in the right seat box. And mesure the ECU in the link. Now I'm in Africa - fog lights would be appreciated for mu return in January.
Everything is orginal no mods but the truck tows. I've already separated the stuff to make sure that the fault ils not related to trailer ans its cables.
I remember having had thèse probkrms before. I jusr changed the switch and everything worked fine. But the inside if the switch is i' perfect condition.
Post #1053034 26th Nov 2024 6:56pm
Julie
Tried it with headlights switched on.
Fog light has been working every 2 years for French MOT Smile
Post #1053036 26th Nov 2024 7:12pm
