Home > Puma (Tdci) > Blue Smoke on Cold Start. |
cozz Member Since: 15 May 2013 Location: nottingham Posts: 539 |
my 2008 2.4 with 131k puffs a bit of smoke on cold start up
23rd Nov 2024 11:15pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
I think they all do it. I have a theory but could be way off... I wonder whether the residual pressure in the fuel rail on shutdown weeps by the fuel injector needle(s) and leaves a small amount of excess fuel sitting in the bore(s) which burns off blue on next startup?
I know that blue smoke usually indicates oil, but my 2.4 does the blue puff at startup yet doesn't use/lose a drop of oil > 110 XS Double Cab |
25th Nov 2024 10:46am |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 108 |
I have an engine heater on mine. If I use it, there is absolutely no smoke. So it's not leaking down injectors. If I don't use it, and it is proper cold, it smokes quite a bit. Zero oil consumption, so it's not that either.
It just is what it is. |
25th Nov 2024 1:09pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20444 |
There is steam as well, sometimes it can seem to be what it isnโt depending on lots of factors. Itโs quite normal anyway No Guts, No Glory.
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
25th Nov 2024 1:14pm |
