Home > Puma (Tdci) > Blue Smoke on Cold Start.
Page 2 of 2 <12
cozz
my 2008 2.4 with 131k puffs a bit of smoke on cold start up
Post #1052720 23rd Nov 2024 11:15pm
hank
I think they all do it. I have a theory but could be way off... I wonder whether the residual pressure in the fuel rail on shutdown weeps by the fuel injector needle(s) and leaves a small amount of excess fuel sitting in the bore(s) which burns off blue on next startup?
I know that blue smoke usually indicates oil, but my 2.4 does the blue puff at startup yet doesn't use/lose a drop of oil > 110 XS Double Cab
Post #1052859 25th Nov 2024 10:46am
Bluest
I get quite lot of blue smoke for the first few yards after very cold start. It's a bit embarrassing, but I don't have an oil consumption issue, so I'm not too worried. It seems to be on the overrun or idle, rather than under power. It definitely look like oil smoke and not diesel to me. I've been pondering whether the low temp lets some oil past the turbo or valve stem seals when the car is sat. 2007 110 TDCi Station Wagon XS
Post #1052861 25th Nov 2024 11:07am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
I have an engine heater on mine. If I use it, there is absolutely no smoke. So it's not leaking down injectors. If I don't use it, and it is proper cold, it smokes quite a bit. Zero oil consumption, so it's not that either.
It just is what it is.
Post #1052873 25th Nov 2024 1:09pm
There is steam as well, sometimes it can seem to be what it isn’t depending on lots of factors. It’s quite normal anyway GBR
Post #1052874 25th Nov 2024 1:14pm
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Changed all the plugs. It was a nice straightforward job.
Biggest worry was them being stuck in. They weren’t in very tight in the end. Only 2 of 4 were working and the other two took ages to dimly glow.
She’s starting smoother, and less smoke when cold.
Thanks for everyone’s input.
Post #1056058 1st Jan 2025 1:30pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Glad you got it sorted.
Glow plug change is on my list but every time I plan to swap them out the weather is crap. The only good thing is that the current glow plugs have been soaked in Plus Gas since Boxing Day.
Jim
Post #1056063 1st Jan 2025 2:36pm
Soaking them and other fixings like that is well worth doing that’s for sure.
I’ve found some things before very tight, left alone, and put some penetrating spray on for days to soak.
Gone back, and it’s undone no problem.
Most of the time you can just tell when not to push your luck on something when it’s overly tight. GBR
Post #1056066 1st Jan 2025 2:54pm
andy63
If you have a plug carbon up which can be usual enough if the glow plugs has been failed for a bit , soaking with some form of release oil for as long as possible is about your only hope of success..pool it in the plug head cavity and run the engine as many cycles to normal temp as you can before attempting.. if its jerky and releases in cracks stop and try lightning a bit before reverting to undoing etc etc..
My last stuck plug was actually clear of the retaining threads and still cracking as you tried to release it..still required a lot of patience and rotating back and forth while trying to exert some upwards pressure to extricate the thing ..😫
When removed i used an appropriately sized twist drill to remove the carbon from the bore
Post #1056071 1st Jan 2025 3:29pm
Ianh
All great advice, one additional bit. If you set a torque wrench to the tightening torque of the glow plug. Then use that wrench in reverse to remove the plug, you can be sure you are not over stressing the plug. Obviously this only applies when the threaded section is still engaged. But does give you more confidence when applying initial torque to break the plug loose.
Post #1056074 1st Jan 2025 3:47pm
Page 2 of 2 <12
