Home > Puma (Tdci) > Blue Smoke on Cold Start.
Page 2 of 2 <12
cozz
my 2008 2.4 with 131k puffs a bit of smoke on cold start up
Post #1052720 23rd Nov 2024 11:15pm
hank
I think they all do it. I have a theory but could be way off... I wonder whether the residual pressure in the fuel rail on shutdown weeps by the fuel injector needle(s) and leaves a small amount of excess fuel sitting in the bore(s) which burns off blue on next startup?
I know that blue smoke usually indicates oil, but my 2.4 does the blue puff at startup yet doesn't use/lose a drop of oil > 110 XS Double Cab
Post #1052859 25th Nov 2024 10:46am
Bluest
I get quite lot of blue smoke for the first few yards after very cold start. It's a bit embarrassing, but I don't have an oil consumption issue, so I'm not too worried. It seems to be on the overrun or idle, rather than under power. It definitely look like oil smoke and not diesel to me. I've been pondering whether the low temp lets some oil past the turbo or valve stem seals when the car is sat. 2007 110 TDCi Station Wagon XS
Post #1052861 25th Nov 2024 11:07am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
I have an engine heater on mine. If I use it, there is absolutely no smoke. So it's not leaking down injectors. If I don't use it, and it is proper cold, it smokes quite a bit. Zero oil consumption, so it's not that either.
It just is what it is.
Post #1052873 25th Nov 2024 1:09pm
There is steam as well, sometimes it can seem to be what it isnโ€™t depending on lots of factors. Itโ€™s quite normal anyway No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1052874 25th Nov 2024 1:14pm
Page 2 of 2 <12
