Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit
Page 6 of 7 <1234567>
B3e4u2nv
Hi Marco,
No I currently don’t have access to changing the ccf, I will search online to see if anyone in London does coding, but for now I’ll use it as a normal mirror. Thanks for the information.
B3E
Post #1047630 3rd Oct 2024 8:08pm
B3e4u2nv
Hi All,
Thank you Marco, you was correct just a simple coding and all done! Very Happy
I have a smart interior mirror if any one is interested as I bought the wrong one at first.
Here’s a picture of it if anyone is interested.
Thanks,
B3E
Post #1048099 9th Oct 2024 7:31am
Darrant1234
Hi, I’m picking up my 110 dynamic x se next week and one thing I will really miss from my 2019 hse evoque is the clear view rear view mirror. I’ve been reading for days on the retrofit and all seems ok ish, but how easy is it to get the old rear view mirror off? Might not have understood how it comes down so any advice would be great.
I’ve found the rear view mirror on eBay using the part numbers in this thread so thank you. Just need an antenna and cable which I will get as I find them.
Post #1050585 2nd Nov 2024 11:12pm
mmbanf
Italy
Post #1050618 3rd Nov 2024 11:22am
Darrant1234
Thanks for the reply. That looks easy enough as long as don’t break the plastic cover in step 1!
I’ve checked on eBay and you can get fakra female to female cables, is there a reason to get the male to female and then the repair cable to get it to female ended?
Post #1050619 3rd Nov 2024 11:32am
mmbanf
Italy
https://www.ebay.it/itm/226306351839?_skw=...R57XpqLeZA
Hi, the Fakra connection cable must be female to female, be careful that the connectors must be of the universal type, therefore they accept male connectors of all colors.
it should be this, if I remember correctly....
Marco
Post #1050625 3rd Nov 2024 1:12pm
Darrant1234
Brilliant thanks. With that cable then, there should be no need for the genuine lr repair cable?
Post #1050627 3rd Nov 2024 1:24pm
mmbanf
Italy
this is a non-original cable, however it is fine, the quality is not Land Rover…., with the repair cable you have the most quality length, I think other users have used this type of cable without any problems.
Post #1050629 3rd Nov 2024 1:30pm
Darrant1234
Thanks again. I’ll get the cable ordered. Just got an Ariel off eBay and brand new rear view mirror. Total cost £360.
Post #1050690 4th Nov 2024 8:11am
Darrant1234
Hi again. So I’ve now got all the bits I need and I’m picking up my defender tomorrow. Thinking about tackling this at the weekend. Are there any tips on getting the cable at the alpine window to the next light hole. Can’t quite make out how to get it behind the window?
Will it make sense once infront of me
Post #1051032 7th Nov 2024 10:00pm
Darrant1234
Hi. So I’ve attempted this today. I got the standard mirror out easy enough and changed the antenna fairly easily. To test I ran the fakra cable from the antenna through car to mirror to check it all works before fiddly bit but I’m not seeing a picture on the mirror. Flicking the lever changes nothing.
Any ideas of what’s wrong? Radio / sat nav etc works fine. Aerial was from an evoque and the mirror was new off eBay. Wiring coming out for the mirror has 6 cables is this right?
Post #1052660 23rd Nov 2024 4:12pm
Darrant1234
Just read about coding above. Sounds same issue as I’m having.
Is anyone near Wakefield / Leeds able to code for a fee / beer tokens?
Not sure I will need a gap tool more than once unless I’m told they come in useful more than once?
Post #1052665 23rd Nov 2024 4:38pm
mmbanf
Italy
hi, sorry it doesn't work....
unfortunately those who have the gap tool will have to pay extra to work on your vin frame.
If you come to Italy for Christmas we can do it Thumbs Up Thumbs Up
Otherwise you can contact Hunters Prestige, David, if you live near them, I think they can do the programming for you for a modest fee.
Marco[/i]
Post #1052676 23rd Nov 2024 6:10pm
Darrant1234
lol thanks for the offer not been to Italy for years. Would be cheaper to buy the tool though.
I’ll message a local independent jlr specialist tomorrow to see if they can assist. Failing that I’ll order the tool.
First though I’ll run cable inside headliner and put trim back on!
Post #1052680 23rd Nov 2024 6:19pm
GAT
You might be surprised how much you end up using the IID tool so think it’s a good investment. If in time you find you don’t use it they hold there price on the second hand market very well.
I think you’d find buying the tool and doing what you need to do then selling it would be the cheaper option Question
Have a read through the activation pages to do with the Gap tool and see what else you fancy Question First Edition 90 in Pangea Green. (Gone)
P400 110 in Tasman Blue.
Post #1052710 23rd Nov 2024 10:34pm
