Home > Puma (Tdci) > steering splines |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Probably 48,but if I were you I would remove the wheel and count them. You should know what the landrover production line was like.
2nd Oct 2018 5:00pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
you don't need to remove the wheel to count. Pull off the centre pad and count the splines by feel with a screwdriver/paperclip/toothpick/whatever. You can do this with the nut still in place. Don't even need to be particularly accurate - if you count more than 36 then it's a 48 spline!
3rd Oct 2018 4:26am |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 379 |
This is very useful.
http://www.web-rover.co.uk/articles-steeringwheels.html |
3rd Oct 2018 7:21am |
Useful but not definitive!
3rd Oct 2018 7:47am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
10 mins ago, before I read this, I just ordered a Optimill steering wheel boss... 48 spline.
Having seen this post, just checked, and mine (2011) is actually 48-spline. I know all later Pumas like ours are supposed to be 48...Best to check tho (as hank says) I guess... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 3rd Oct 2018 8:40am. Edited 1 time in total |
3rd Oct 2018 8:08am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
You try being definitive with this topic.... I've done my best! 1988 90 Td5 NAS soft top
2015 D90 XS SW |
3rd Oct 2018 8:39am |
Haha "Land Rover" and "definitive" can never be synonymous!!
3rd Oct 2018 9:02am |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
It literally takes less than a minute to remove the wheel... Best to check...
Only advice is leave the nut on a few turns before you 'shock' the wheel off so it doesn't come flying toward your face Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
3rd Oct 2018 8:14pm |
C90 Member Since: 19 Nov 2024 Location: Essex Posts: 18 |
I have been crawling the internet all week to find the answer to this question for my 2007 90, I had convinced myself without doubt that it was 48 then read a few things this morning that have changed my mind! So I have no clue now. haha.
So... using the excellent advice from you fellas on here... I am going to bump the wheel off and count them! I'll let you know my findings. |
20th Nov 2024 11:31am |
No need to take the wheel off! > 110 XS Double Cab |
20th Nov 2024 11:42am |
I missed your original comment Hank, thanks for that!
20th Nov 2024 11:45am |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 120 |
There are also different spline thicknesses, which I found out the hard way. My 2009 48 is “thicker” than a 48 for an earlier Defender.
21st Nov 2024 5:37am |
