Home > Puma (Tdci) > steering splines
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
steering splines
hi
got a 2011 double cab 110 xs what number of splines is it likely to have, would like to have to avoid removing and counting and then having to refit and wait for boss, i assume is 36 or 48?
cheers
Post #732385 2nd Oct 2018 8:23am
williamthedog
Probably 48,but if I were you I would remove the wheel and count them. You should know what the landrover production line was like. Rolling Eyes
Post #732519 2nd Oct 2018 5:00pm
hank
you don't need to remove the wheel to count. Pull off the centre pad and count the splines by feel with a screwdriver/paperclip/toothpick/whatever. You can do this with the nut still in place. Don't even need to be particularly accurate - if you count more than 36 then it's a 48 spline!
Post #732627 3rd Oct 2018 4:26am
edo
Post #732641 3rd Oct 2018 7:21am
hank
Useful but not definitive!
Post #732651 3rd Oct 2018 7:47am
MartinK
10 mins ago, before I read this, I just ordered a Optimill steering wheel boss... 48 spline.
Having seen this post, just checked, and mine (2011) is actually 48-spline.
I know all later Pumas like ours are supposed to be 48...Best to check tho (as hank says) I guess... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #732658 3rd Oct 2018 8:08am
Martin
Site Admin
You try being definitive with this topic.... I've done my best!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #732663 3rd Oct 2018 8:39am
hank
Haha "Land Rover" and "definitive" can never be synonymous!!
Post #732671 3rd Oct 2018 9:02am
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
It literally takes less than a minute to remove the wheel... Best to check...
Only advice is leave the nut on a few turns before you 'shock' the wheel off so it doesn't come flying toward your face Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #732816 3rd Oct 2018 8:14pm
C90
I have been crawling the internet all week to find the answer to this question for my 2007 90, I had convinced myself without doubt that it was 48 then read a few things this morning that have changed my mind! So I have no clue now. haha.
So... using the excellent advice from you fellas on here... I am going to bump the wheel off and count them! I'll let you know my findings.
Post #1052292 20th Nov 2024 11:31am
hank
No need to take the wheel off! > 110 XS Double Cab
Post #1052294 20th Nov 2024 11:42am
C90
I missed your original comment Hank, thanks for that!
Post #1052296 20th Nov 2024 11:45am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
There are also different spline thicknesses, which I found out the hard way. My 2009 48 is “thicker” than a 48 for an earlier Defender.
Post #1052375 21st Nov 2024 5:37am
