Home > My Defender > Defender 110 V8 Dormobile
Page 4 of 4 <1234
Electron
Nudging ever closer ...
Post #1049077 18th Oct 2024 4:13pm
L110CDL
She sure is Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1049093 18th Oct 2024 7:25pm
Electron
So I'm going up later in the month to make the MegaJolt Loom in situ. Going for 16" steel rims with zero offset to try to get a bit more steering lock. The stereo is built into the headlining and needs sorting. A few other minor bits 'n bobs and we're there. As always the journey was longer and more involved but hopefully I'll have a much better truck to play with ..
Post #1050536 2nd Nov 2024 1:10pm
L110CDL
Great pic of the front and as in most cases, the journey is always longer than we first think Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1051023 7th Nov 2024 8:26pm
Electron
So we wired up the MegaJolt, EDIS 8, Coilpacks and Crank Sensor over the past couple of days. Everything went really well until we came to turn the thing off !! Leakage from the alternator into the white feeds prevented the relays from cutting things out. Took ages to fathem but we got there.
The engine sounds fantastic with the new 9:35 pistons, rebuild with new cam, valves, big ends, mains etc. The exhaust is perfect with not much more noise but better flow.
We've added a Lambda Sensor bung so with the MegaJolt showing revs and manifold pressure and the sensor showing mixture it is so much easier to set up and optimise.
We also added the extra temperature sensor for the MegaJolt to alter the timing for cold startup. This drops out gently as the thing warms up. She now starts on the button first time every time (Before was a cranking nightmare especially when hot.)
There are a few more "campervan" bits to do and some interior reassembly but we're getting ever closer ..
Post #1051719 14th Nov 2024 11:17am
L110CDL
Very Happy Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1052334 20th Nov 2024 7:53pm
Page 4 of 4 <1234
