Home > Tdi > Rubber Mats |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1628 |
200tdi is a different shape to the 300, which is the same as the td5. So no “Puma/tdci” ones won’t work. I think the best solution for Mats in these are the nice exmoor “autograph” ones and they’re not too dear and fit well.
20th Nov 2024 1:30am |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
The below aren’t cheap but are worth it.
P/N VPLDS0686 |
21st Nov 2024 8:58am |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 625 |
I did some work on a 300tdi recently and noticed it had the latest Puma mats fitted, looked neat enough with a minor trim although there was so much wrong with it looking at the mats was the last thing on my mind.
I have always liked the genuine td5 Land Rover mats in my 300tdi, however they last about a year before they wear through, next time I will replace them with Autograph mats mentioned above as they are a thicker rubber in the wear area. Also bear in mind the Puma mats above are no more hard wearing than the td5 type - what looks like blocks of solid rubber are actually hollow underneath |
21st Nov 2024 10:32pm |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 784 |
I have had these in my Tdi for 9 years and they are still as good as the day I fitted them which is good given they are relatively cheap.
https://www.paddockspares.com/da4423-rubbe...-1984.html BORG - Bucks & Oxon 4x4 Response Group |
22nd Nov 2024 3:13pm |
They’re the same as the exmoor ones as above
4th Dec 2024 10:05pm |
