- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Puma (Tdci) > Puma not starting after stalling.[SOLVED] Likely fuel filter |
Ianh
It may well have been a poor, blocked or badly sealing fuel filter. Noting some aftermarket ones do not seal as well.
Alternatively it could have been contaminated fuel, blocked filter and damaged VCV.
At least it’s now running
17th Nov 2024 4:38pm |
Waka56
Yes it is
My injectors are also way quieter. Wondering if I should empty that tank fully.
Is it fairly easy to fully drain or does the tank need to be removed? Making my Defender great again. (Or trying to at least xD)
17th Nov 2024 9:20pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
