![]() | Home > Puma (Tdci) > Puma not starting after stalling.[SOLVED] Likely fuel filter |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20699 ![]() ![]() |
Accidental double post*
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 170 ![]() ![]() |
I went back to January when I changed my injectors, I could do the injectors learning, but not the pump relearn if I remember well. Already back then I had the P268B. I think I deleted the error and since the engine was running really well it slipped my mind. Making my Defender great again. (Or trying to at least xD)
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 910 ![]() ![]() ![]() |
Why don’t you just change the VCV? It’s a 20 minute job at most.
Jim |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
I have had this too. Honestly change the VCV. You say have one there in the box - it is a ten minute job and only needs an allen key. Why would you not? Read my post here about time and money wasted when the cause was the VCV all along https://www.defender2.net/forum/topic53240-245.html > 110 XS Double Cab |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
Indeed. The VCV is located between the LP and HP stages of the pump and regulates the amount of fuel passing from the LP to the HP, consequentially regulating fuel rail pressure. |
I think I just should get to it, it´s just that I have seen from 10 mins to 2 hours job haha. Making my Defender great again. (Or trying to at least xD) |
Do it, you know it makes sense you only need a ball ended hex (Allen) key, just don’t overtighten the fixings, just nip them up that’s all.
Job done. ![]() |
7 N.m
![]() Tomorrow before work. Making my Defender great again. (Or trying to at least xD) |
Blackwolf - Good to hear, so I would have thought if the injectors were seeing below expected pressures compared to standard parameters say at idle, then the VCV could be tracked down to being the cause.
Though there is a possibility that one injector or even two injectors might be out of range but all four, would be far less probable. (That would suggest injectors need replacing anyway). So that could be used as an example, I seem to remember the rail / injector pressures are very high somewhere in the region of 20 to 26k PSi, (approx, don’t quote me on exacting pressures) so certainly not something to handle when active I.e the injectors themselves.. What is the typical signs of injector issues out of curiosity? I know that the spray pattern can go out of uniformity so to speak with age, but I can’t see how that can be found unless sent for testing. I would imagine, even though expensive that it practically pays just to replace, than to mess around with testing, and recalibrating etc. Though it’s not a cure all potion, this is why I use the diesel Millers additive permanently, as it adds lubrication for the fuel pump, helps keep any diesel bug under control and keeps fuel components clean as much as you could hope. There is still the risk, of contaminated fuel, but that’s sadly not anything that we can do anything about. I have read before in diesel magazines, engine techs when dismantling an engine with high miles found that components were in really good condition compared to without using it. I would imagine it helps counter the effects of the bio percentage too. Going a bit off on a tangent here, I know but it always pays to learn these things, not just tech knowledge but H&S details as well along with it. |
I know that not everyone likes rebuilt injectors, but that's what I went for. Directly after swap and relearn the engine was as smooth as it gets, but after 5-6k a slight injector rattle came back, wondering if that could be VCV related, can't wait to get it running again and check it out. Pretty sure I got some bad diesel when I nearly reach the bottom of the tank 3-4k km ago, right before the rattle came back. Making my Defender great again. (Or trying to at least xD)
So vcv changed. Good news is, the car started.. but I don't know if it started because I insisted more than the other times or not.. managed to start it 3-4 times, but always stalls again after, can't keep it on even if revving. Idle does not sound good. Might put some new diesel as I am in the last quarter.
Edit: I put the battery on charge, I'll check some more later. Making my Defender great again. (Or trying to at least xD) |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2230 ![]() ![]() |
Poor fuel, fuel contamination and water can all contribute to the failing of a 2.4 VCV.
So When did you last change or drain your fuel filter ? I’m wondering if it’s blocked or if there is water in it. |
Filter is 10 months old, 8.000kms. I have not drained it once, I'll do it later, what's the procedure?
Edit: seems quite easy to drain. Do I need to top up the filter afterwards or the fuel will be replaced automatically? I don't see water inside, the fuel is not 100% clean but I'll have to do it again, could come from the drain itself. I ordered a new diesel filter that should arrive tomorrow. I‘ll change the Filter, add some fresh diesel and then check the under the sit relays again. If I can I‘ll also delete all DTCs and then start fresh. Last EDIT: I changed the fuel filter, added a bit of fresh filter and it started after a while and idled nicely straight after. How long does your fuel filter usually last with no problems? I was planning on changing it yearly with the normal service, did not expect to see it die before.. Maybe it was it the fuel filter, the new VCV or the fact that the battery was unplugged overnight, or maybe a bit of everything. Anyway, I'll have to see if this happens again. Making my Defender great again. (Or trying to at least xD) |
