![]() | Home > Td5 > Td5 sound |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
What exhaust and what parts do you have fitted?
Betsy Member Since: 05 Aug 2024 Location: Derbyshire Posts: 26 ![]() ![]() ![]() |
As far as I’m aware it’s all standard
It’s a 1999 so has no cat, I’m tempted to put a centre delete pipe in
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 235 ![]() ![]() |
3inch down pipe and no silencers should do the trick, certainly does on mine.
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
TD5 with no centre silencer is a reasonable compromise.
Not too loud, but has a slightly more satisfying low down grumble. Weirdly, ours used to drone something rotten in the cab when the centre silencer was fitted- it's possibly slightly noisier now but is a less unpleasant frequency/sound somehow. Chris Last edited by Chris86 on 13th Nov 2024 6:28pm. Edited 1 time in total |
That’s interesting Chris, thanks, that’s kind of what I’m thinking
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 531 ![]() ![]() ![]() |
The best ones I’ve heard on You Tube were made by Demand Engineering. I’ve used Longlife custom exhausts on several vehicles and have been very pleased with the outcome. I think a larger diameter pipe changes the note on diesels quite a bit, makes it deeper. 1983 110 automatic OM606
The demand ones do sound good, I think you might be right about going to a larger diameter, iv heard that before, In fact some say it actually makes to car quieter
