Home > Td5 > Td5 sound |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
What exhaust and what parts do you have fitted?
12th Nov 2024 9:00pm |
Betsy Member Since: 05 Aug 2024 Location: Derbyshire Posts: 9 |
As far as I’m aware it’s all standard
12th Nov 2024 9:03pm |
It’s a 1999 so has no cat, I’m tempted to put a centre delete pipe in
12th Nov 2024 9:47pm |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 223 |
3inch down pipe and no silencers should do the trick, certainly does on mine.
12th Nov 2024 9:50pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 789 |
TD5 with no centre silencer is a reasonable compromise.
Not too loud, but has a slightly more satisfying low down grumble. Weirdly, ours used to drone something rotten in the cab when the centre silencer was fitted- it's possibly slightly noisier now but is a less unpleasant frequency/sound somehow. Chris Last edited by Chris86 on 13th Nov 2024 5:28pm. Edited 1 time in total |
12th Nov 2024 10:01pm |
That’s interesting Chris, thanks, that’s kind of what I’m thinking
12th Nov 2024 10:12pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 475 |
The best ones I’ve heard on You Tube were made by Demand Engineering. I’ve used Longlife custom exhausts on several vehicles and have been very pleased with the outcome. I think a larger diameter pipe changes the note on diesels quite a bit, makes it deeper. 1983 110 automatic OM606
13th Nov 2024 8:02am |
The demand ones do sound good, I think you might be right about going to a larger diameter, iv heard that before, In fact some say it actually makes to car quieter
15th Nov 2024 7:14pm |
