Home > Maintenance & Modifications > Ashcroft LT230 1.100 Gear Set
Page 2 of 2 <12
Zed wrote:
That’s really interesting, let us how you get on. Usually the complaint is the opposite with revs being to low when motorway cruising. Some even swap out 6th gear for the lower ratio transit version which pushes up revs further to relieve excess wear on the main shaft.
How does speeding up the main shaft "reduce wear" on it?
Post #1051099 8th Nov 2024 7:28pm
Zed
“Labouring” was the reason I was given but I don’t know exactly, which is why I found the OP’s solution so interesting.
This is from Winchester’s website, both owners I spoke with had fitted uprated gearboxes with transit 6th gear purchased from them:
“ Depending on your wheel size or transfer box ratio you might benefit from fitting the 0.77 lower ratio transit 6th Gear. Fitting the lower ratio can put you in a more comfortable rev range. labouring in 6th is a common cause of mainshaft wear.
Here are a few examples.
Standard 6th gear at 70mph 30inch tyres 2496 RPM
Standard 6th gear at 70mph 32inch tyres 2340 RPM
Transit 6th gear at 70mph 30inch tyres 2614 RPM
Transit 6th gear at 70mph 32inch tyres 2428 RPM”
https://www.winchestergears.com/performanc...4270-p.asp
Are they mistaken? WARNING.
Post #1051110 8th Nov 2024 8:45pm
Allowing any engine to labour is bad, but I rather fail to see how running a shaft faster reduces wear. I suggest that in the absence of scientific evidence people should make up their own minds. Very Happy
Post #1051114 8th Nov 2024 9:09pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
Is it not the fact the shaft is moving faster but the increase in RPM pushes it further up than where peak torque is produced 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1051117 8th Nov 2024 9:41pm
jst
I can see the benefit of the transit 6th gear option. Higher revs for those on std tyres std tune towing heavy loads on long motorway journeys.
Or those running larger tyres and std tune.
Although it's not something I have ever considered to increase revs as its only top gear.
When I needed more oomph I fitted a 1.3t box.
When I wanted more relaxed causing on a torque engine light vehicle I went 1.003. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1051172 9th Nov 2024 5:49pm
Dinnu
Believe that it has to do with the cyclic loads. If need to maintain the same speed so power on the engine, when using a taller gear, the cylinder pressures need to be higher at lower engine RPM, and the flywheel and clutch plate springs are not able to fully absorb these cyclic loads.
I think same reason the diff pins tend to elongate their respective hole.
That's how I understand it, stand to be corrected though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1051186 9th Nov 2024 7:25pm
Naks
Zed wrote:
Naks wrote:
Right, but mine is remapped + various other mods, so when I'm cruising on the highway, I often try to change up a gear from 6th to 7th 🤣
Blimey! What is the speed limit there? I don’t think I have ever got near the rev limiter in 6th.
Speed limit is 120 km/h, and by then I'm at 2500 rpm. But there's more power in reserve, and I can't access it without everything shaking itself to death Whistle --
Post #1051301 11th Nov 2024 8:49am
Naks
How's that for service from Ashcroft? Placed the order on Thursday afternoon, and it arrived at my house on Monday morning Thumbs Up
With the extended sump, what quantity of oil does the transfer box take now? --
Post #1051417 12th Nov 2024 12:49pm
MK
+0.5 liter. Some say 0.6 liter. So just at level (and not more) of the filler hole. Puma 110" SW
Post #1051420 12th Nov 2024 12:57pm
jst
that is great service, let us know how you get on with it. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1051431 12th Nov 2024 2:41pm
MK
I suggest you tap the sump as its lower point seats lower than the std drain hole.
And if you install it dry, it is likely you will need a bit more than 3 l of oil. Puma 110" SW
Post #1051756 14th Nov 2024 6:08pm
Page 2 of 2 <12
