Home > Puma (Tdci) > Puma pushing out coolant |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 818 |
Replace the expansion cap first. The pressure valve is common for failing and not opening.
Cheap fix, fingers crossed. 2008 2.4 110 Utility Station Wagon XS. |
3rd Nov 2024 10:22am |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 514 |
The expansion tank cap has been replaced according to the post..
One way of establishing a head gasket failure into the coolant space is to use a scope with either a pulse sensor or a pressure transducer.. Connect the tube to the expansion tank in such a way as it doesn't suffer vibrational movement if you are using the pulse sensor.. If there is a leakage you will see it on the trace as a rhythmic rise in pressure , and if you use an injector as a cylinder reference you can even tell which cylinder is responsible.👍 |
3rd Nov 2024 1:29pm |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 19 |
Thanks for the replies.
Yes, the cap is only two month old and it has not leaked until this week. Worth a try with another one I guess. The pulse sensor sounds nice but not in my tool box at the moment. Will keep it in mind if/when I consult with a workshop. If the release valve in the cap is working as it should, would excess pressure still result in the leaks that I am seeing? Or would the gas just be released to the atmosphere? |
3rd Nov 2024 2:58pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1999 |
A faulty EGR cooler can let exhaust gasses into the coolant and pressurise the system. You could temporarily remove the two hoses from the EGR cooler, join them together, then run engine to see if the issue is rectified.
Noting a failed EGR cooler is a rare occurrence on a 2.4. |
3rd Nov 2024 3:31pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Have you consider a combustion leak test? As well you could use a camera and check for bubbles coming into the expansion tank. Puma 110" SW
3rd Nov 2024 3:34pm |
Hi Ian... can a leaking egr cooler pressures the cooling system.. the exhaust gas manifold pressure is always tending towards atmospheric pressure with small pulses.. well below the pressure of the coolant on a running engine so how will it add pressure to the coolant system?
I can see gas been drawn into the coolant as things cool possibly.. And back to the op.. if the header tank cap keeps venting due to high pressure then it will carry coolant with it as it opens..Just like you get an eruption of coolant when you crack a cap on a pressurised system i imagine.... |
3rd Nov 2024 3:53pm |
I was thinking CO2 test to begin with, if that is negative and problem persist a cylinder compression test. Am I right in avoiding pressure testing the cooling system if there is a risk of leakage into a cylinder?
Regarding the EGR cooler, I was hoping to take it out of the equation as I fail to see how it can pressurise the cooling system. If it is easy enough to bypass the cooler I’ll try that too. Thanks for the advices so far! |
3rd Nov 2024 7:24pm |
Well, I guess you will get a + with the CO test being the source either from EGR cooler or blown gasket/crack head. So the best it would be to start by bypassing the EGR cooler as mentioned. I would be careful to make those hose connection quite safe not run out of coolant. Puma 110" SW
3rd Nov 2024 7:43pm |
