Home > Puma (Tdci) > Someone Must Have An Answer! Manifold To Turbo Seal. 2.2TDCi
roddyfox
South Africa 2013 Defender 110 Puma 2.2 SW Santorini Black
Question Could someone categorically tell me please what forms the seal between the manifold and turbo charger on the 2.2 TDCi engine, as mine is leaking exhaust gas. Nakatanenga tell me that their high strength gasket is specifically for the 2.4 TDCi engine (and older ones). Likewise I can't find anyone else, such as Bearmach, Britpart etc. stating that their gasket is for the 2.2 TDCi. Photo shows serious leak. Many thanks. Question
Post #809593 9th Jan 2020 7:00pm
Crash7
Thread revival! - Did you ever fix this? If so how?
Post #1050407 31st Oct 2024 11:10pm
roddyfox
Yes, but I took the vehicle to a Land Rover specialist in the end - I can't quite recall what he did but can ask him tomorrow.
Post #1050426 1st Nov 2024 6:37am
roddyfox
(A lot has happened since then - the Covid era and a new engine!)
Post #1050428 1st Nov 2024 6:43am
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I had a similar issue with an exhaust smell in the cab. I took it to the garage for a smoke test & they found a leak between exhaust manifold & turbo. They told me that the problem was that the gasket between manifold & turbo was missing and so they fitted one.
Now I'm googling I can only see a gasket for the 2.4 and not the 2.2 & I'm wondering if it should ever have had a gasket? Anyway this was a few years ago and it seemed to fix it.
Post #1050430 1st Nov 2024 7:46am
The 2.2 WSM indicates that there is no gasket between the turbo and exhaust manifold on the 2.2.
Post #1050443 1st Nov 2024 10:20am
MK
Yes, the 2.4 needs/comes with a gasket between the exhaust manifold and the turbo. Ford p/n 1505921
 Puma 110" SW
Post #1050468 1st Nov 2024 4:41pm
