![]() | Home > Puma (Tdci) > Another stalling puma, with a twist. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 488 ![]() ![]() |
Apologies for sounding of..it's not possible to see other folks problems on the end of a keyboard😫 ..
Of course you do what you have to do and take the best option for yourself.. I can see why the parts is your best option... Hope it's easily sorted 👍 |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1616 ![]() ![]() ![]() |
He’s using picoscope
Yes, as mentioned its a picoscope .. The automotive version as opposed to the labs scope.. But I have a little handheld dso that serves as a multimeter or scope , made by onwon, that is OK for quick checks , without the need to drag laptops out etc 👍 |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 142 ![]() ![]() |
Ffs.. brought the ODB tool, came 30mins early to realise I forgot the car key
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 245 ![]() ![]() ![]() |
Hi andy63
Could you send me a link to the pico unit you use please? TIA 2011 130 Utility Body 2005 110 Van |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1969 ![]() ![]() |
Once you have the key
![]() Even if no DTCs then you can still check the wiring continuity from each sensor to the ECU with a multi meter, visual check wiring for chafing, check connectors are not damaged. See wiring diagrams three and four on this link https://www.lrworkshop.com/wiring-diagram/...e-controls. Once you have tested / checked the wiring given you have purchased the camshaft and crankshaft position sensors already, I would change the crankshaft position sensor first, see if that rectifies the issue. If not then change the camshaft position sensor to see if that rectifies the issue. |
Hi... here is a link to the pico automotive site..and various products..
https://www.picoauto.com/products/automoti...t/overview The scope I've been using up till fairly recently is a 4423...which is a 2 channel automotive scope..i doubt its available now..I've had it years..but the equivalent will be the new 4225A.. the decision will be whether to go for a 4 channel scope , which if you get into this sort of thing is handy, but at the time I couldn't afford one so got a 2 channel which I've only recently changed for a 4 channel.. Pico we're never cheap but the price appears to have shot up in the last few months😳.. Their software is free and constantly been upgraded ..and generally regarded as a top quality product even if expensive to buy the hardware.. |
That 4423 should read 4223...ie the 4000 series 2 channel ...
Yup I'll make sure to bring the multimeter with the keys 😬 Making my Defender great again. (Or trying to at least xD)
