Home > Puma (Tdci) > Defender front caliper torque
Page 2 of 2 <12
Before now I have stripped calipers where the only way to get the piston out has been to split the caliper then to drill and tap a hole in the back of the piston and use a bolt as a jackscrew to force the piston out. Despite the pistons being that badly stuck, the calipers have generally been salvageable.
On the whole now though I am of the view that the cost of a new quality caliper is so low that it isn't worth the effort of overhauling one, the hours involved in doing a decent job simply aren't worth it. If you want stainless pistons, fit them in a new caliper. If you don't, then just replace the calipers every five years or so.
Post #1037715 17th Jun 2024 8:08pm
Does anyone happen to know the spanner size for the 2.4 Puma 90 brake bleed nipples?
Also any tips on a perfect tool for the job?
I have everything else, just need to get the right spanner.
There are a few options on the market for brake bleed spanner’s so anyone have any suggestions for a really good tool for the job?
There are flare nut types, a type with integral seal and nipple, / colour coded and ring spanner type, I think a spanner with flats is just best avoided as will slip and possibly round. Which would be a nightmare in itself so certainly don’t want to do that. KEEP CALM AND Drill ON
Post #1049964 27th Oct 2024 6:30pm
landy andy
Aren’t the bleed nipples 11mm. And if tight use a socket, to snap it loose, then spanner.
Post #1049978 27th Oct 2024 8:06pm
jst
11mm. Alot of the specific brake spanners don't fit as the sides are too thick on the pipe inlets, you can get away with them on the bleeds. I tend to use the ring end of std spanner. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1049986 27th Oct 2024 8:40pm
Thank you. Thumbs Up
Post #1049989 27th Oct 2024 8:53pm
TexasRover
Rebuild a few calipers over the years, never had an issue popping the pistons out with compressed air. Keep your fingers well clear and use a c clamp to place back and hold the pistons that popped. As said replacement calipers are affordable but a piston seal kit is more affordable still.
Recently rebuild my rear calipers on my 110 and took maybe 30 min a side. Should be good for another 10 years, went for normal chromed rather than stainless.
Post #1050005 28th Oct 2024 7:32am
landy andy
If anybody wants a not too bad set of rear callipers let me know, I’ve got an old pair on my garage floor.
Post #1050011 28th Oct 2024 8:27am
Page 2 of 2 <12
