![]() | Home > Puma (Tdci) > Defender front caliper torque |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20672 ![]() ![]() |
Does anyone happen to know the spanner size for the 2.4 Puma 90 brake bleed nipples?
Also any tips on a perfect tool for the job? I have everything else, just need to get the right spanner. There are a few options on the market for brake bleed spanner’s so anyone have any suggestions for a really good tool for the job? There are flare nut types, a type with integral seal and nipple, / colour coded and ring spanner type, I think a spanner with flats is just best avoided as will slip and possibly round. Which would be a nightmare in itself so certainly don’t want to do that. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5833 ![]() ![]() |
Aren’t the bleed nipples 11mm. And if tight use a socket, to snap it loose, then spanner.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8186 ![]() ![]() ![]() |
11mm. Alot of the specific brake spanners don't fit as the sides are too thick on the pipe inlets, you can get away with them on the bleeds. I tend to use the ring end of std spanner. Cheers
Thank you.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1184 ![]() ![]() ![]() |
Rebuild a few calipers over the years, never had an issue popping the pistons out with compressed air. Keep your fingers well clear and use a c clamp to place back and hold the pistons that popped. As said replacement calipers are affordable but a piston seal kit is more affordable still.
Recently rebuild my rear calipers on my 110 and took maybe 30 min a side. Should be good for another 10 years, went for normal chromed rather than stainless. ![]() Click image to enlarge |
If anybody wants a not too bad set of rear callipers let me know, I’ve got an old pair on my garage floor.
