Home > Puma (Tdci) > Hello & help ! Power loss, lock barrels, mystery cables
Fataitch
United Kingdom 2010 Defender 110 Puma 2.4 PU Portofino Red
Hello all.
New to the forum (110 SCPU now a convertible). I’d post a photo if i could work it out.
so saying hello first and asking for a little help please.
Firstly - out driving this evening and experienced power loss, didn’t quite stall but virtually no power. Switched off for a few minutes and all fine for a couple of miles then gone again. Managed to limp home.
Truck has been dry stored for 2 years and used very little. 1/4 tank of diesel of unknown age. I will check coolant level and fuel filter as soon as I can. Advice on here suggests VCV issue ?
Can I drain the fuel tank and flush it ?
Secondly - can I have the same key to operate the rear safari lock as well as the two front doors, fuel cap and ignition ?
Thirdly - I’ve got a bunch of wires connected to a grey 12 pin connector block (6x6) coming up behind the dash clocks onto the top of the dash - if only i could post a photo !! 6 wires going in purple/white, purple/blue, purple/brown, 2 x black, black/brown, white/black. Any ideas what this was connected to ? I’m thinking interior lights as they've all gone since the conversion - I’m only asking as the Haynes manual doesn’t recognise any purple wires for the interior lighting circuit.
Post #1049903 27th Oct 2024 1:28am
Fataitch
Here we go
Post #1049918 27th Oct 2024 12:20pm
PaulMc
The grey connector connects to the roof harness, for interior lights and the alarm volumetric sensor. Paul.
Post #1049960 27th Oct 2024 7:10pm
Fataitch
Cheers Paul
Post #1049976 27th Oct 2024 8:58pm
jst
Nice
Same key can do door locks and ignition but not fuel cap with standard lr barrels. Not sure if there is an aftermarket barrel for fuel cap conversion.
Grey plug interior light connector.
I would fill it with diesel, change the fuel filter.
Sounds more like blocked tank breather and tank vacuum. Try it with the fuel cap not quite so tight, with similar fuel level to what you currently have. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1049981 27th Oct 2024 9:21pm
Fataitch
James
Thanks for your input. Having a pocket full of keys is annoying Evil or Very Mad
I’ll have a look at the tank. I drained the fuel filter today but no water and everything was clean (as it’s been filtered i guess Very Happy ) will look at your suggestions.
Thanks
Post #1049999 28th Oct 2024 12:05am
Fataitch
Update - power loss was due to low coolant. Water pump was leaking and I’d lost about half the fluid - no temp warning lights though. New water pump fitted and coolant flushed & refilled - no more issues.
Whoever did the work prior to my ownership fitted early handles - puma barrels don’t fit (too long) - so will replace ignition, door barrrels AND door handles to get down to 1 key for all.
It’s dark with no interior lights ! Next job on list to do.
Thanks for your help.
Post #1051379 12th Nov 2024 12:33am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
You can download an electrical manuals here:
https://www.4x4community.co.za/forum/showt...al-Manuals
Just follow the diagrams and connectors until you find your issue.
Post #1051386 12th Nov 2024 5:35am
Fataitch
That’s helpful, thankyou.
Post #1051418 12th Nov 2024 1:51pm
