Home > In Car Electronics > Hazard light bulb
22900013A
Hazard light bulb
It appears the bulb has failed in my hazard switch. The power lead snapped recently which I repaired, but now it seems the bulb has gone. The switch does not light up with the headlights on, nor flashes when pushed.
I can only see one tiny build that pops out when I turn it, is this the only light? And where can I source a replacement? Could anything else make it not work? I can see no damage to the wiring. The switches are stupidly expensive to replace. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #1029694 29th Mar 2024 12:56am
rustandoil
It's possible to dismantle the switch and fit a new bulb, Iused a "Scalextric" bulb sourced from Ebay... Only because I couldn't at the time find "grain of wheat" bulbs used in model railways.... It's a fiddly job if i remember but doable with care, good luck ๐Ÿคž
Post #1029698 29th Mar 2024 6:47am
Martin
Site Admin
There are a few threads on here with the part number for the bulb Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1029701 29th Mar 2024 7:32am
22900013A
I tried searching but the eBay links were all old and no longer worked. I think I need stc1205? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1029710 29th Mar 2024 8:57am
22900013A
If seems to come apart easily enough, I just the replacement bulb. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1029711 29th Mar 2024 8:58am
Martin
Site Admin
Luckily you wonโ€™t get ripped off on EBay then. The price is bad enough without the markup eBay sellers add.
STC1205 is the correct part  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1029721 29th Mar 2024 9:37am
Does anyone know the bulb type for these? Am I correct in assuming that they are the same 1.2w capless type the same as behind the centre dash?
I think mine has gone in the hazard switch โ€ฆ
The PN above isnโ€™t available from some places and includes the holder, Iโ€™d have thought just changing the bulb would be fine to do?
It seems from the pics that itโ€™s just the standard bulb, unlike the clock that has a coloured cover / screen as well which is more annoying to deal with. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1049660 24th Oct 2024 3:17pm
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I now wish I took a pic when I had mine out. I ordered what I thought was a replacement bulb but said bulbs were too large/long to fit and the bulb in the holder is oh so tiny.
These bulbs are also used in model trains and cars, as mentioned further up. Land Rover parts websites sell them but at a hefty price for a small bulb.
I did clean the contact points on mine thinking maybe it wasn't the bulb but then the other day I happened to tap the hazard switch and it lit up!
Good luck
Post #1049665 24th Oct 2024 3:40pm
Philm
Post #1049668 24th Oct 2024 4:13pm
286 1.2w capless type, often made by Lucas but there is Genuine as well, which is likely the former anyway.
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
As far as Iโ€™m aware thatโ€™s the size the centre dash takes, I do know they are 1.2w for sure. Play Stupid Games, Win Stupid Prizes.
Post #1049677 24th Oct 2024 5:44pm
Puma_MOG
I bought those bulbs and when I had the Hazard bulb holder out, I could not for the life of me see how they would fit. Perhaps I should give prizing the bulb a go and see.
Please report back if you give this a go yourself Smile
Post #1049687 24th Oct 2024 6:45pm
The bulb should pull out like the others do, they are a push fit but equally itโ€™s so thing you have got to be careful of is to not break the bulb.
A drinking straw may fit, but some pliers with electrical tape on the bulb may work too but youโ€™d need to be careful to only grip it lightly* or the bulb will break.
Tomorrow Iโ€™ll see if I can get the bulb out and have a look. Thumbs Up Play Stupid Games, Win Stupid Prizes.
Post #1049691 24th Oct 2024 6:59pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
This is mad, I came on here to ask about the bulb also, but we have an electronic repair facility on site where I work and they had them in stock.
Radionics sell them and the code is 655-9198
https://ie.rs-online.com/web/p/incandescent-light-bulbs/6559198
Shane
Post #1049748 25th Oct 2024 12:31pm
