Home > In Car Electronics > Hazard light bulb |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
It appears the bulb has failed in my hazard switch. The power lead snapped recently which I repaired, but now it seems the bulb has gone. The switch does not light up with the headlights on, nor flashes when pushed.
I can only see one tiny build that pops out when I turn it, is this the only light? And where can I source a replacement? Could anything else make it not work? I can see no damage to the wiring. The switches are stupidly expensive to replace. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
29th Mar 2024 12:56am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 748 |
It's possible to dismantle the switch and fit a new bulb, Iused a "Scalextric" bulb sourced from Ebay... Only because I couldn't at the time find "grain of wheat" bulbs used in model railways.... It's a fiddly job if i remember but doable with care, good luck ๐ค
29th Mar 2024 6:47am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
There are a few threads on here with the part number for the bulb 1988 90 Td5 NAS soft top
2015 D90 XS SW |
29th Mar 2024 7:32am |
I tried searching but the eBay links were all old and no longer worked. I think I need stc1205? 2011 110 USW
29th Mar 2024 8:57am |
If seems to come apart easily enough, I just the replacement bulb. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
29th Mar 2024 8:58am |
Luckily you wonโt get ripped off on EBay then. The price is bad enough without the markup eBay sellers add.
STC1205 is the correct part 1988 90 Td5 NAS soft top 2015 D90 XS SW |
29th Mar 2024 9:37am |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 |
I now wish I took a pic when I had mine out. I ordered what I thought was a replacement bulb but said bulbs were too large/long to fit and the bulb in the holder is oh so tiny.
These bulbs are also used in model trains and cars, as mentioned further up. Land Rover parts websites sell them but at a hefty price for a small bulb. I did clean the contact points on mine thinking maybe it wasn't the bulb but then the other day I happened to tap the hazard switch and it lit up! Good luck |
24th Oct 2024 3:40pm |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 171 |
24th Oct 2024 4:13pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20454 |
286 1.2w capless type, often made by Lucas but there is Genuine as well, which is likely the former anyway.
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0 As far as Iโm aware thatโs the size the centre dash takes, I do know they are 1.2w for sure. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
24th Oct 2024 5:44pm |
I bought those bulbs and when I had the Hazard bulb holder out, I could not for the life of me see how they would fit. Perhaps I should give prizing the bulb a go and see.
Please report back if you give this a go yourself |
24th Oct 2024 6:45pm |
The bulb should pull out like the others do, they are a push fit but equally itโs so thing you have got to be careful of is to not break the bulb.
A drinking straw may fit, but some pliers with electrical tape on the bulb may work too but youโd need to be careful to only grip it lightly* or the bulb will break. Tomorrow Iโll see if I can get the bulb out and have a look. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
24th Oct 2024 6:59pm |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 509 |
This is mad, I came on here to ask about the bulb also, but we have an electronic repair facility on site where I work and they had them in stock.
Radionics sell them and the code is 655-9198 https://ie.rs-online.com/web/p/incandescent-light-bulbs/6559198 Shane |
25th Oct 2024 12:31pm |
