Home > Td5 > Indicator Stalk
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Indicator Stalk
The indicator stalk on my 2002 TD5 is getting very vague and floppy (a bit like me). It was an advisory on the last MOT and has deteriorated since then.
The bay of thieves has Lucas ones at £37.96 and various others going down to £18.88
Obviously Lucas is little more than a brand name applied to products from India and China nowadays and the quality is often questionable.
Anyway, has anyone tried one of the cheaper ones or been able to compare the Lucas ones against the cheaper alternatives?
Post #1049499 22nd Oct 2024 10:26pm
rustandoil
I recently fitted a Lucas indicator switch from Paddocks..... It works, but is just as vague as the one I took off..... Just hoping that the actual switch contacts are just a little better quality than the cheaper versions
Post #1049505 23rd Oct 2024 5:10am
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I bought one of the super-cheap copies, it 'works'. But the self-cancelling fails to operate semi regularly. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1049521 23rd Oct 2024 10:24am
Procta
Re: Indicator Stalk
If you can go for the more expensive unit, your better off. As you will end up buying again with in a matter of months, I had a hazard switch fail on me with in a matter of months too on my 300 TDI, i managed to get hold of a proper Lucas unit. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1049550 23rd Oct 2024 3:00pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Agreed with Procta, buy yourself OE (Lucas) or genuine if you can. Its false economy otherwise.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1049563 23rd Oct 2024 5:22pm
Mo Murphy
Lucas is cheap Chinese/ Indian license made tat. Avoid at all costs.
50 Shades of Pennine Grey
Post #1049596 23rd Oct 2024 9:46pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
I fitted one of the cheap £18 ones a couple of weeks ago.
Took it out the box and thought it looked pretty good. All worked as it should.
The box had nothing other than some spurious number on it.
I wouldn’t be surprised if it was identical to the £37 ones, but without printing on the box.
For the amount of bits it is made from, then assembly, and postage, I thought it was a bargain even if it only lasted a year.
Post #1049656 24th Oct 2024 2:50pm
Often or not Genuine is Lucas, Lucas is pretty good but all of them aren’t infallible build quality.
Keep an eye on the electrical connectors and that they are tight and secure, they can be a bit loose and pop off, so be sure they don’t come off before fitting.
So if you do find a loose one, take it off and ever so slightly tighten the connector, and then fit so it is secure.
If there is a blue indicator cancelling ring, be sure it’s fitted the same way it came off and also marries with the tangs on the back of the steering wheel if present before final fit.
It isn’t complex, but is annoying if it all goes back together then you need to get back there due to something like I’ve mentioned above.
Only lightly nip up the securing screw as well, they are really good for snapping and then the whole assembly is loose, a single small drip of Loctite 222 might be a good idea too but as I mentioned, the securing screw around the column only needs to be tightened just enough to secure it and no more. KEEP CALM AND Drill ON
Post #1049662 24th Oct 2024 3:26pm
SteveK
Cheers guys.
In the end I ordered a Lucas one, however it is in an old style box and so I am hoping that it is a new old stock item and decent quality!
It is due to arrive today!
Post #1049832 26th Oct 2024 8:48am
